2000 yz426 ring tolerance?
4 replies to this topic
  • Tevonini
Posted December 28, 2012 - 05:37 PM
I just got my brand new wiseco piston In and I wana throw it in the bike, my only question is what is the ring tolerance? I don't have a manual it never came with the bike when I bought it thanks in advance
Posted December 28, 2012 - 06:43 PM
Free Manuals:
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
Comp ring end gap is .008-.012" (0.20 - 0.30mm)
Oil ring end gap: .010-.020" (0.20 - 0.50mm)
  • Tevonini
Posted December 28, 2012 - 06:46 PM
Thanks greyracer you have alot of knowledgable answers and I always apreciat when you answer my questions
  • SWIGIN
Posted December 30, 2012 - 08:00 AM
If you have a new piston then you should have the needed paper work to figure out your ring gap.
Always use the piston manufactures specs, Yamaha did not make that piston or rings so why would you gap them to there spec.
Posted December 30, 2012 - 09:33 AM
When they're available, that's fine, but for a huge majority of the time, you'll find that the OEM and aftermarket rings will call for end gap numbers that are very nearly identical.
Compression rings will run roughly .003" per inch of bore, while oil rings are closer to .005" per inch of bore.
  • Hot  50 replies
  • On January 15, 2017
  • Hot  30 replies
  • Hot  28 replies
