Advice about Forgotten Dowel pin WR450
4 replies to this topic
  • hafte
Posted December 28, 2012 - 08:13 AM
Hi All,
I have one quick question.
When i join my WR450 bottom end, I was installed the o-ring (with small amount of liquid gasket) between to cases, but forgot to put dowel pin. The oil pressure is low, and feed only oil thank in the frame.
I will be a problem?
  • hafte
Posted December 29, 2012 - 11:01 PM
I was split engine again and solve the problem.
  • JDLowrance
Posted December 29, 2012 - 11:13 PM
Good idea as without the dowel pin there is no guarantee the o-ring will seal.
  • MANIAC998
Posted December 30, 2012 - 05:07 AM
I know it's alot of work, but that is what needed to be done. You need that oil going where it's designed to go!!!
  • hafte
Posted December 30, 2012 - 05:26 AM
It is not so much work. It took me 4 hours to split and join all :-), but it was for good, i hope.
