Factory Bent Subframe How to fix it???????
7 replies to this topic
  • Miker
Posted November 18, 2003 - 10:06 AM
Hey there. I have grown tired of walking up on my 2000 XR650
from the rear and seeing the subframe bent to the left. I read somewhere once that this is standard from the factory and can be bent with a large bar to be straight. My question is what if anything do I have to remove and where should I pry at? :)
  • BWB63
Posted November 18, 2003 - 05:38 PM
I use the bar after I remove the sub frame beat it to death (ok, not that hard but, enough to take out some of the bend) with a large hammer at the two bends on the left side on the top rail that goes to the frame and the bottom bends that on both sides. makes it real hard to get back on the bike. Once on I put a block of wood on the swing arm (no air box or fender, Just a bare sub frame bolted on the bike) and give it it's last tweak. I have done seven bikes (six for others) and it turns out real straight. One I didn't have help to hold the bike so I came up a little short from getting all of the bend out. Once you get it together it not as hard to get it back on latter. There is still a lot of up push to hold it from bending again.
  • MLB
Posted November 18, 2003 - 07:02 PM
What? From HONDA? What the....?
  • MLB
Posted November 18, 2003 - 07:03 PM
Why don't you take it back to the dealer and have THEM do it. Under warrenty?
  • smashinz2002
Posted November 18, 2003 - 09:14 PM
My 2000 650R was like that too when I bought it. But I got it used, and I thought the bend was from a fall or something, so I didn't think much of it.
I took off the rear fender, inserted a steel pipe between the two subframe rails which stick out the back, and pryed it some. It didnt take much really, and now it's straight enough to where you can't notice any bend.
Now I hear the bike comes this way even new! That's pretty odd and I'm surprised Honda would do something like that. But I'm not going to complain too much, because I've ridden this bike for 2 years and over 5000 hard off road miles, and it's never given me any kind of mechanical trouble at all and it still doesn't use any oil. I've only had to adjust the valves once so far also.
  • Miker
Posted November 19, 2003 - 10:43 AM
Thank's for the replys. I think I will try the pry the subframe method after removing the fender. I think I will loosen the exhaust pipe junction as well as it seems the pipe would have to shift a little too. :)
  • J_T
Posted November 19, 2003 - 11:12 AM
This maybe a dumb question but if its bent from the factory and its been on about every model since 2000, Could there be a reason? I can't think of one.
Mine doesn't rub and I have not straightened it. I guess I never noticed it. I'll look next time but if its bent from the factory I'm sure mine is too!
Why should I straighten it? Why are ya'll straightening it, cosmetic reasons or something else?
I know its alot of why questions but I'm curious?
JT
  • qadsan
Posted November 19, 2003 - 12:21 PM
I too have seen a few that were bent on the showroom floor. Mine bent after a few jumps, so I thought it might have had something to do with the weight/intertia of the stock exhaust can from jumping or possibly from the suspension bottoming out, etc. I never gave it much more thought and keep a spare just for that day when I can no longer bend mine back. I'm happy as long as mine doesn't interfere with the rear tire.
Fell Off Trailer by usafxr
  • Hot  43 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  158 replies
  • Hot  35 replies
  • 3 replies
  • Hot  28 replies
