Wrapping a std tube in an endurotube
9 replies to this topic
  • wrwest
Posted December 22, 2012 - 05:11 AM
Who is using this and comments pls
  • MANIAC998
Posted December 22, 2012 - 06:49 AM
What's an Endurotube?
  • GuyGraham
Posted December 23, 2012 - 02:32 AM
Think he means the tyre inner tube, and wrapping the tube with another tube to prevent puncture
Just get yourself some Michelin UHD tubes - these are 4mm thick rubber and you will not get a puncture
  • wrwest
Posted December 23, 2012 - 09:48 AM
I do use the UHD tubes and get punctures from thorns where I ride so need to replace them at cost! all the time . Looking for a cheaper alternative - Wrapping a standard tube with a UHD and saving money.
  • wrwest
Posted December 23, 2012 - 09:49 AM
I use a 6 mm tube by the way.
Edited by wrwest, December 23, 2012 - 09:50 AM.
  • MANIAC998
Posted December 23, 2012 - 12:50 PM
What about using a Moose foam insert instead of a tube? If you do any kind of high speed highway riding, it's probably not an option though.
Edited by MANIAC998, December 23, 2012 - 12:50 PM.
  • highmarker
Posted December 23, 2012 - 01:26 PM
considered tougher tires? 2 extra plys built into a good desert or dualsport tire (6ply vs 4ply mx tire)
Edited by highmarker, December 23, 2012 - 01:36 PM.
  • GuyGraham
Posted December 24, 2012 - 01:45 AM
If you're getting frequent punctures on a 6mm thick tube then they are some serious thorns, and I wouldn't like to take a tumble where you ride!
Swap to a moose and your problems will be solved
Edited by GuyGraham, December 24, 2012 - 01:47 AM.
  • wrwest
Posted December 24, 2012 - 11:05 AM
moose is not an option due to price! . i just wanted to know is there are guys on here that uses this setup, I am not looking for options or alternatives as I know them all , mooses , tubless, enduro tubes , tennisballs in the front and rear , tyre balls .
Yes you read right tennisballs in the tyres works well , and much cheaper than tyreballs, just dont last long.
thanks anyway.
  • miweber929
Posted December 26, 2012 - 05:45 AM
If you get thorn punctures in 4 mm tubes where you ride you better hope you never fall or you'll bleed to death!!!
Seriously, though, any tube-within-a-tube is going to generate a TON of heat and destroy itself in short order, like your tennis balls do. In this case to ride where you want to ride you need to get a mousse or you're going to keep getting punctures, money or not. Watch the classifieds, sell your body, 3rd job, whatever, but it will pay for itself after a short time.
This is not a cheap sport and to play you gotta play; but know dirt is far cheaper than street. I used to work 3 or more jobs a time to afford tires and track days, proper dirt tires last a long time compared to track tires which can go in a weekend at $300 a set.
