Can pre-09 YZ450F wheels be made to work on a 2010 YZ450F?
6 replies to this topic
  • smokingtz
Posted December 21, 2012 - 08:08 PM
Have a set of 03 wheels. What are the differences between them and 09 -up wheels? Of course I'll probably sell my 03 wheels and buy 10 wheels but would like to know
  • WouldsAssassin
Posted December 21, 2012 - 10:08 PM
Front will work, rear is different. If you are looking to buy a set of wheels for '10 and up PM me.
Posted December 22, 2012 - 09:52 AM
The '09 and later rear wheel uses a 25mm axle, while the earlier models back to '99 use a 22mm axle. At this point, no bearings exist that will convert the earlier hubs to the larger axle size.
  • KJ790
Posted December 23, 2012 - 07:07 AM
You can make it work with a pre-09 axle and axle blocks on the 09-up swingarm. I believe you will have to modify the axle blocks, but there was someone on here not too long ago that made it work.
Posted December 23, 2012 - 08:39 AM
You "can" use the early axle blocks with an early axle to fit the rear wheel, but that places the weight bearing load on a portion of the swing arm not originally intended for it. If you made a pair of steel sleeves for the blocks that have a wall thickness of .060" (1.5mm) so that they extend into the swing arm axle slot, it would be some what more sound.
  • KJ790
Posted December 23, 2012 - 05:46 PM
That's the route I would go personally, or at least make sleeves for where the axle goes through the swingarm and use the old axle blocks.
  • smokingtz
Posted December 25, 2012 - 12:28 PM
I was hoping for different bearings but we'll see. just want it in case i get flat and don't have time to fix right away.
  • Hot  36 replies
  • On January 15, 2017
  • Hot  38 replies
  • 0 replies
