Will a Holeshot Device for a 2008 YZ250 fit my 2006?
12 replies to this topic
  • Ih8Hondas
Posted December 15, 2012 - 07:49 AM
I thought they ran the same forks from 2006-current, but apparently they changed the length of the stanchions in 2008. It should still work if all they changed is the length though, right? Anybody know for sure on this?
  • RCannon
Posted December 15, 2012 - 08:30 AM
They did shorten them a few mm. But nothing that will hurt anything. The 06 was delivered with 5mm of fork showing above the upper triple. The 06 was delivered flush.
Be advised, you also need a 08 front axle and axle spacer to put thinks back together.
  • Ih8Hondas
Posted December 15, 2012 - 10:51 AM
So they are the same stanchions then, just set at different heights from the factory? All I'm doing is looking to get the correct holeshot device, but Motosport isn't showing one for a 2006. Only 2008+, which led me to ask this question.
  • Ih8Hondas
Posted December 17, 2012 - 01:48 PM
Anyone else? All I'm worried about is the part where the holeshot device clamps on the outer tube and whether they changed it when they shortened them.
  • paulschauer
Posted December 17, 2012 - 02:10 PM
Physically the collar should fit since the fork tubes are the same diameter. The 06 and 08+ fork guards are different, so I imagine the template you put on the fork guard to drill the holes to mount the latch wouldn't line up correctly? This is for the WC ProLaunch I have, the template exactly matches the 08+ fork guard.
I think you could get a holeshot device to work fine but you'll have a little trial and error getting the latch set to the height you want since the template won't line up exactly on the 06 fork guard like it does on the 08+ fork guard. You'll also have to compensate for the stanchion height difference, I can't confirm that difference though.
  • BRM
Same stanction diameter. it will fit no problem.
  • Ih8Hondas
Posted December 18, 2012 - 09:12 AM
Alright. That's what I wanted to know. Thanks, guys.
  • RCannon
Posted December 18, 2012 - 09:58 PM
Wait a second..I remember trying to use the black, 2008 lower fork guides on my 06 forks. They were too marrow to fit in the groove where the white 06 guide sat. Is this where the holeshot device fits?
  • Ih8Hondas
Posted December 19, 2012 - 01:24 AM
Google Works Connection Pro Launch. That's what I'm planning to order. It has a collar that goes around the lower end of the stanchion and the catch mechanism that screws to the fork guard. Assuming the info the other two provided regarding the stanchions is correct, the only issue I should have is setting the mechanism to compress the forks the desired amount. That is unless the radius of the newer style fork guards is drastically different from the '06 ones, which I doubt. Probably wouldn't make much of a difference even if they are.
  • pdyz125
Posted December 19, 2012 - 11:07 AM
hmm maybe just order a set of fork guards too with your wholeshot device?
  • Ih8Hondas
Posted December 19, 2012 - 11:23 AM
I would still probably have to do trial and error. If they made the stanchions shorter I assume there's more tube sticking out of the bottom that the guards have to cover up. Anyone have any answers for that? Will new style fork guards fit on the '06 fork lugs?
  • RCannon
Posted December 19, 2012 - 04:01 PM
One of the guards fits, the other wont. The brake side will work on any model, The non brake side wont. Just Yamaha f-ing with us as they changed it in 08.
  • Ih8Hondas
Posted December 19, 2012 - 04:18 PM
Crap. Oh well. Trial and error it is then.
What would you buy? by 2000YZ250
  • Hot  45 replies
First Harescramble by 2000YZ250
  • Hot  29 replies
Hero Dirt in the High Desert by 2strokeYardSale
Yamaha YZ85 2017 by Chris.GVS
Yamaha YZ85 2017
  • 0 reviews
Squish or #8 slide? by yz dude
  • Hot  27 replies
