2012 wr450f what map comes on comp ECU?
3 replies to this topic
  • Jmulhollen
Posted December 09, 2012 - 10:22 PM
Have a question for those out there. Picked up by bike the other day and broke it in. Have the comp ECU as well as fmf gytr pipe to toss on. I have a question though.....what mapping comes on the comp ECU? I didn't buy a tuner and probably can't until after Christmas.
Now that I'm on the topic I noticed today that after the bike was warm I didn't notice a change in idle when turning the screw. Are these much less sensitive that carbs when it comes to turning in or out an idle adjustment screw? First FI bike.
Thanks!!!
  • tomerb
Posted December 10, 2012 - 03:16 PM
When you hook up the Power Tuner for the first time you'll see all zeros and that's the stock map.
I road mine with the stock map to see what it was like a few rides than adjusted from there.
  • Jmulhollen
Posted December 10, 2012 - 10:45 PM
I assumed I would need the tuner......jackpot!
  • tomerb
Posted December 11, 2012 - 05:50 PM
You will need a tuner to change the base map but it will run fine with the base map.
