fork and shock springs
13 replies to this topic
  • yam450
Posted November 16, 2003 - 07:23 AM
Anybody replace their fork and shock springs? I weigh 240lbs and I was wondering what type springs would be best for my weight. The springs on my '03 WR are way to soft. Any suggestions?
'03 WR450F :)
  • RunAnywhere
Posted November 16, 2003 - 12:49 PM
Call your local suspension shop. I priced Race Tech components and they were only 50-70 bucks cheaper than ESP did the hole thing for. It also cuts out a lot of time loss with trials and errors.
Good Luck
  • Alabama_Rider
Posted November 16, 2003 - 02:48 PM
I am also looking for replacement springs as I weigh 200 and they are way to soft. Got a quote from XR's only. Who is ESP?
  • Indy_WR450
Posted November 16, 2003 - 04:31 PM
5.8 kg rear spring with stock front springs works for me at 230 lbs. :)
  • yam450
Posted November 17, 2003 - 06:48 AM
Thanks, I will check into it.
  • RunAnywhere
Posted November 17, 2003 - 08:08 AM
Exceptional Suspension Products. They are a West Coast specialist. I'm very happy with the job they did on mine. Front forks weren't a huge difference, but the rear is amazingly superior. Worth the investment.
818.951.9144 Talk to Chad.
Good Luck
  • yam450
Posted November 17, 2003 - 11:29 AM
Thanks, I will try them.
  • wrkaholic
Posted November 17, 2003 - 04:14 PM
I weigh about the same as you. I went with an Eibach 5.8 rear spring and left the rest of the suspension stock. It works great for me. Really helped on the whoops. Leave plenty of sag.
  • yam450
Posted November 17, 2003 - 04:16 PM
Thanks, is there an online store where I can purchase the springs?
  • Spokes
Posted November 17, 2003 - 04:35 PM
How much sag? I just had Rocky Mountain Racing Works revalve my bike and they put a 5.1 rear spring on it. It had 5.5 inches of sag when I got it back. I rode it before I checked it. I thought it was good. I checked the sag and set it 4 inches. Now, it handles too fast. It doesn't feel as stable, etc... I do like how it keeps pegs up out of the ruts better. I think I'm going to try 4.5 - 4.6 inches.
  • Indy_WR450
Posted November 17, 2003 - 05:42 PM
I run 3.6" of rear sag with the forks raised 15 mm in the triple clamps! My bike is very stable and still does not turn as quick as a KTM 450 EXC or CRF450. Maybe your steering head bearings are loose? :)
  • Balcs
Posted November 19, 2003 - 10:06 PM
Really, the best thing I did was had my suspension completely revalved. I contacted John at Motopro in Woodinville Washington and he dialed my WR450 in perfectly for off road and when I moto, I just stiffen it up and it is extremy plush. I did not need to put stiffer springs in the front. (The fork spring rates are the same as the YZ's)It's all valving and the stock valving on the WR Absolutely Blows! You have not ridden until you get a revalve and you will be kicking yourself for not revalving from the beginning. It is so worth the money because you will get less arm pump, it rides higher in the stroke and the bike is way more controled at high speeds and chop. Get R Done! :)
  • Alabama_Rider
Posted November 20, 2003 - 09:50 AM
What else can be done to make this bike turn tighter? The woods we ride are very tight single track. Has anyone gone to a 20" front? Already have raised forks.
Posted November 24, 2003 - 06:47 PM
I weigh 245, I replaced the front springs with 49's, and the rear a 60...There is a local shop in San Diego that did the valving work for me, and it is absoulutely perfect...He can let you know based on weight, and ability what to use...GREAT GUY....Rudy Casteneda..Owner of PRO PREPT SUSPENSION / Escondido 760-489-5774
