WR400 fork seals question
4 replies to this topic
  • cb650joe
Posted November 27, 2012 - 07:28 PM
I have a 2000 WR400 that needs new fork seals. Who makes the best seals? And, are they difficult to change? Any other tips, tricks, surprises I should know about. The only fork seals I have done, were on an '81 Honda CB650, and those were not difficult and did not require any special tools.
  • Spiritwalker2222
Posted November 29, 2012 - 02:00 PM
changing the fork seals is easy, but you'll need a damper rod holder. I think motion pro makes one for around $50.
You can download the shop manual from Yamaha if you don't have a hard copy.
http://www.yamahaown...ook.com.au/?r=0
  • cb650joe
Posted November 29, 2012 - 07:09 PM
I actually have the shop manual for the bike, but was unsure if special tools were needed. I just had a dealer quote $200 to do the job, so I may just bite the bullet, and have them do it.
  • n16ht5
Posted November 30, 2012 - 05:57 PM
rockymountain has this fork seal tool for $25 that has kept me leak free on the stock 2007 seals so far so good. they have sprung a few leaks and it cleans the seals out and fixes it
http://www.rockymoun.../fork seal tool
  • mikewrf18
Posted December 03, 2012 - 06:59 AM
I just made my own damper rod holding tool and fork seal driver and it cost next to nothing and have lasted me for years.
You now need a damper rod holding tool. Take a flashlight and look down inside the fork tube to get an idea of what the tool should look like. You're going to be making a castle nut remover basically the female version of a +. Go to home depot and buy a 1" piece of black gas pipe. Take a grinder and shape the end of the pipe to fit. Be careful and make be sure to do a good job in shaping the business end of the tool (and the tool will work for years). Once you've shaped the end you can drill 1/4" hole through the other end of the pipe so you can use a screw driver to hold it in place when in use.
If you don't have a seal driver (and you should) you can make one out of 2"or 2-1/2" PVC pipe split down the middle
http://www.thumperfa.../fork_seals.htm
Edited by mikewrf18, December 03, 2012 - 07:01 AM.
