Is an overflow bottle really needed?
12 replies to this topic
  • stev0
Posted November 20, 2012 - 05:15 AM
Im busy setting up my YZ426 for woods and dune riding and wanted to know if the overflow bottle really is needed (and worth the $$$)
Its at the shop doing some much needed maintenance, so really just looking for some feedback? I figured that the bike will get hot either way if it stands and idles on the trail or in really technical riding.
  • FinchFan194
Posted November 20, 2012 - 09:40 AM
Turkey basted mod only costs about $10! Totally worth it and necessary IMO.
  • High_Boost
Posted November 20, 2012 - 01:13 PM
whats the turkey baster mod?
I overheat me bike and boil out the coolant every time I ride the technical trails near me.
I purchased a wr overflow bottle I was going to try and use, but it looks like it will interfere with the rear tire with the yz subframe, so I am not sure yet.
  • Gunner354
Posted November 20, 2012 - 03:39 PM
No need to install an overflow with Evans . It's unlike any other coolant you are used to. It is waterless and has a boiling point of approx. 365* F.
www.evanscoolant.com
  • WouldsAssassin
Posted November 20, 2012 - 04:37 PM
Here's a few ideas for you.
http://www.thumperta...-overflow-tank/
  • rmx rider
Posted November 20, 2012 - 07:31 PM
I have an '07 450 and started to ride the woods with it, almost right away ( as in the first ride) the engine overheated in the slower sections resulting in coolant loss. As I continued with the bike in the woods the condition persisted and I kept having to monitor the loss and top up the rad. I eventually installed an overflow, first a plastic sports drink bottle mounted under and to the side of the rear fender. The bottle worked fantastic, the bike still overheated but the fluid loss was contained and flowed back to the rad when the engine cooled. Problem here was the plastic was too brittle and the bottle failed. After that I changed to the turkey baster mounted on the inside of the rad, its on there now working great. Less capacity than the first bottle but enough and easy to make and easy to install. Have a look on utube for some tips.
  • rhinoracin
Posted November 20, 2012 - 07:46 PM
I think The only time a coolant catch tank is needed is if youre riding very slow single track for a long time. I put engine ice coolant in all my bikes, and for my yz it made a huge difference
Posted November 20, 2012 - 11:32 PM
Since the problem is caused by a lack of air flow, the way to cure it is to provide air flow, i.e., install a small fan. You can run one for a couple hours off of a 9 volt cell. If you use a WR426 flywheel and stator, you can run it from that.
  • High_Boost
Posted November 21, 2012 - 07:54 AM
there are defiantely some good ideas in those threads.. it will give me something to play with over thanksgiving weekend :)
Gray - do you think only 1 radiator needs a fan, or should one be installed on each rad?
I would think both, but my riding buddy has a crf250x and the factory cooling upgrade on his bike is 1 fan on the fill radiator
Posted November 21, 2012 - 08:44 AM
One does the trick a lot of the time. Something on the order of a computer case fan.
Be sure your coolant is fresh, mixed right, and that your cap is OK.
  • STR8SHOOTR
Posted November 21, 2012 - 04:55 PM
I have the Boyesen Impellor and use engine ice, never boiled over in the trail while riding.
Posted November 21, 2012 - 09:06 PM
A lot of things changed between '01 and '06, too.
BTW, I think that the WR426 radiators bolt onto a YZ426. I can't recall if there was a conflict with the shrouds or not. The WR radiators are larger.
  • STR8SHOOTR
Posted November 22, 2012 - 05:40 AM
Your correct, I forgot what model the op had. But it did make a bid difference on my bike. 06 450 And I didnt mention that I only ride in the winter months in Florida 75-85 degrees
Edited by STR8SHOOTR, November 22, 2012 - 05:42 AM.
Motocross
  • Hot  491 replies
  • 0 reviews
  • Hot  94 replies
