07 WRF... retard cam, hotcam, or yz450f cam?
68 replies to this topic
  • n16ht5
Posted November 17, 2012 - 09:07 AM
since I am in adjusting my valves I want to get some more power with cam mods. I seem to have a hard time finding a concrete answer as to which is the best power to money cam mod to do.
retard the exhaust cam one tooth
yz450f exhaust cam
hotcam
+yz450f intake cam>??
I have this link to retard the stock cam a tooth.. which requires decomp pin milling...
http://www.yfzcentra...50-cam-mod.html
what should I do? Any of you WA guys want some free beer?
Chris
  • n16ht5
Posted November 17, 2012 - 02:01 PM
okay well I'm going with the retarded wr cam. I ground 1mm off the decomp pin and I am going to reinstall tomorrow. Hopefully no valve parties ensue...
  • Bandit9
Posted November 17, 2012 - 05:13 PM
Have you done the stiffer Accelerator Pump spring yet? Like the Merge Racing AP spring?
  • n16ht5
Posted November 17, 2012 - 09:50 PM
No, but I did the O ring mod. carb mods, YZ head pipe, lexx exhaust, desmogged, de-corked, etc..
Edited by n16ht5, November 17, 2012 - 09:51 PM.
  • Bandit9
Posted November 18, 2012 - 04:27 AM
Just checking b/c I thought the extremely improved throttle response with the stiffer AP spring, YZ complete exhaust, and clean jetting made it just right for single track. I have to be around 51-53 HP right now.
I was under the impression that you couldn't do the retard on the newer WR's, and that replacing it with the OEM YZ cam or Hotcam was the only way. But then you could possibly run into problems with the E Start not working, which is why I didn't mess with the cams. I like my E Start, especially with the Shorai battery.
You are a lot braver than I am. Very interested in how this turns out, keep us posted.
Ain't no party like a valve train party!
Edited by Bandit9, November 18, 2012 - 04:32 AM.
  • n16ht5
Posted November 18, 2012 - 06:40 AM
hmmm.. what does the stiffer spring do vs the o ring????
  • Bandit9
Posted November 18, 2012 - 06:58 AM
Supposed to accomplish the same thing. However O rings stretch easily and would diminish the response over time. Where as the spring is consistent for quite a while I would imagine. But since you already know what it feels like by doing the O ring mod, it probably wouldn't give you the power you are after.
Edited by Bandit9, November 18, 2012 - 06:59 AM.
  • Bandit9
Posted November 18, 2012 - 07:01 AM
Might try the AP spring anyway since it is cheap, I paid $5 for this little wonder at CycleGear. Maybe your O rings are worn out and this would give you the kick that seems to be missing.
  • n16ht5
Posted November 18, 2012 - 10:46 AM
i used a small zip tie, no wearing out
  • n16ht5
Posted November 18, 2012 - 09:05 PM
well it's back together and running again with the ex cam retarded a tooth and valves shimmed back in spec. Dumping rain and I need to rewire a few things so I'll try to ride it later. I'm glad this thing is so fun to ride because it really kills the time trying to work on it!!
few things I learned
-give yourself 30 minutes just to get the valve cover off. then take a break and come back and try it again. very tight clearance
-make sure you stuff lots of rags over the motor.. lots... somehow a c clip managed to sneak past the rags I had stuffed in there and migrated down all the way to the flywheel.
-there are two little c clips that love to go flying when you pop off the valve retainer cover deals... no matter how gentle you pry them.
  • MANIAC998
Posted November 19, 2012 - 04:57 AM
This is an instant classic!!! And this should be a "sticky"!!!!
  • Bandit9
Posted November 19, 2012 - 03:37 PM
Thanks for the tips. You get to ride it today?
  • n16ht5
Posted November 21, 2012 - 09:00 PM
finally got it all back together. It runs like a raped ape! I just took it for a quick spin down the driveway a few times, dark and raining out.. but it runs better than I was expecting... much more snap right off the bottom. I need to re-jet the carb now.
Also, the E start works better than before! It doesn't seem to hang on the compression stroke as much now. Best free mod so far.
pics:
-starting...
valves have moved... probably not a great thing, but the bike has 150+ hard hours and this is the first time they needed to be adjusted
exhaust cam decomp pin
pin out it measures .940
dremeled down .040 or 1mm.. then rounded and sanded smooth with a few grades of sandpaper to a shine.
back together, greasing bolts (swingarm bolt) if you haven't ever greased yours, do it. there are pics on the xr400 section of a guy who resorted to cutting off his entire swingarm from a frozen bolt.
not even a full season on this skid plate.. call that a good year :)
now my lights and accessories only come on with my ignition too :) (relayed the wiring harness)
Edited by n16ht5, November 21, 2012 - 09:05 PM.
  • Bandit9
Posted November 22, 2012 - 04:54 AM
Nice work!
  • beezer
Posted November 22, 2012 - 08:50 AM
You can't get any better than free.
I put a YZ exhaust cam in mine and the e-start hangs up on a compression stroke sometimes but it made a huge difference in power from top to bottom.
Good work!
  • Bandit9
Posted November 22, 2012 - 02:53 PM
Yeah this is the first I've seen be able to do it like this.
  • MANIAC998
Posted November 24, 2012 - 05:06 AM
How is the power output? Does the power come on to strongly? With the limited traction out here, smooth power is good power, so I was just wondering. Thanks!
  • Bandit9
Posted November 24, 2012 - 06:41 AM
Also after you get a few hours on it, let us know how the E start is working.
  • n16ht5
Posted November 24, 2012 - 06:09 PM
went for a trail and ds ride today... oh man it rips!! it tractors like an xr but pulls out like a yz450 on top. e start worked every time all day. I cant believe how much better it runs.
do this mod!
  • still2smokin
Posted November 24, 2012 - 06:20 PM
do this mod!
I didnt see in the link where it said anything about grinding down the decomp pin. Maybe I missed it but does this need to
be done to all WR's ?
I am seriously thinking about doing this.
