How to remove Sprocket Nut ?
12 replies to this topic
  • GlennR
Posted November 12, 2012 - 07:37 PM
Is there a trick to removing the big nut that holds the front sprocket on?
How do I lock up the engine to loosen it? I know about putting rope into the spark plug hole, but that might not be the best thing for the WR.
I know some guys swap out sprocket sizes pretty often, so it must not be too hard, but I haven't do it before and don't want to wrestle a lot with it or break anything.
Should I use Loctite when replacing it?
  • usdualsports
Posted November 12, 2012 - 07:43 PM
Impact will get it off since is spins fast. If you don't have an impact you can have a buddy sit on the bike put it in gear and apply the rear brake. I have also had to put an item in the rear sprocket to keep it from moving like a rag around the chain. To do it correct use an impact.
  • jawknee21
Posted November 12, 2012 - 09:55 PM
I just put one back on yesterday. I would use loctite. An impact makes it easy. I kept it in neutral but had someone push the back brake while the chain is still on...
  • GuyGraham
Posted November 13, 2012 - 04:09 AM
Line bike up perpenduclar to a wall & put front wheel against wall
bike in first gear
sit on bike
back brake fully on
3 ft breaker bar with socket on the c/s nut
  • usdualsports
Posted November 13, 2012 - 04:11 AM
bike in first gear
sit on bike
back brake fully on
I like the bike against the wall idea why didn't I think of that.
  • MANIAC998
Posted November 13, 2012 - 04:25 AM
Loctite isn't needed when re-installing the nut. That's what the lockwasher is for.
  • William1
Posted November 13, 2012 - 04:57 AM
Use an impact. It is the least stressful on the bike.
  • GlennR
Posted November 13, 2012 - 06:04 AM
Thanks guys.
I'll pick up an impact wrench/gun. Been wanting one anyway... I figured that was the best way.
  • jawknee21
Posted November 13, 2012 - 09:22 AM
maybe im missing it but i cant find the sprocket on the fiche. what is it under?
nevermind found it. Under transmission...
Edited by jawknee21, November 13, 2012 - 09:27 AM.
  • mslow
Posted November 13, 2012 - 11:53 AM
i use a tripled up piece of safety wire and go through one chain link then to a hole in the rear sprocket, all while in nuetral.
no brake needed, i usually work alone so sometimes you have to improvise
  • cwallershasta
Posted November 13, 2012 - 12:00 PM
I never had one that was to tight where I couldn't just set the bike on the ground and chock the rear wheel to get it off, but WD40 might help and I always clean up the spline on the shaft with it too. No need for locktite as you have the fold over spline washer, witch I buy and extra one to have if needed. I think after a couple of times of removal the washer gets comprimised folding it over the nut and it's good to just put a new one on.
Edited by cwallershasta, November 13, 2012 - 12:00 PM.
  • YamaLink
Posted November 13, 2012 - 02:14 PM
Me trying to do it without an impact is a comedy of errors.....and a giant waste of time.
  • GlennR
Posted November 17, 2012 - 05:11 AM
Bought a $20 impact gun from HF, which did the job. Then when installing the new one I realized that my torque wrench is only a 3/8" and I need a 1/2"....Arrrg! Always "something".
