Throttle Stop or Not?
6 replies to this topic
  • NSXRYDER
Posted November 12, 2012 - 05:35 PM
i just bought a 2000 WR400F and noticed that there's no throttle stop for full throttle.there's a threaded hole for something,but nothing there.i'm just worried that it was needed.looking at the slide, the slide goes completely up,will it get jammed up?
i'm thinking the screw was left out by the past owner or the dealer when he dropped it off to them.
i cant find the part number if i do need it.
please help~
Gary
  • William1
Posted November 13, 2012 - 04:56 AM
You need the throttle stop.Get the YZ one.
I beleive the part number is 3TJ-14325-40-00 but you need to confirm it.
  • NSXRYDER
Posted November 13, 2012 - 01:41 PM
How far do you tighten the screw? Do you bury it,or does this act as a restriction?
And whats different about the yz stop screw?
Thanks, Gary
  • Taxgod4u
Posted November 13, 2012 - 09:29 PM
Tighten screw until it seats. The YZ screw is shorter than the WR so you can use the full range of your throttle. OR read the sticky posts at the top of the WR seciton on how much to cut/grind off of your WR screw and save $17.00. IIRC the screw stops the rotation of the pully that the throttle cables attach to. Acts like a govenor. Without it you can effectively turn the throttle to a point of no return and hang it at WFO with no way to easily unstick it while hurdeling towards that cliff/jump/parked truck etc.
  • supermega1
Posted November 14, 2012 - 02:27 PM
Here's a post i made in regards to the 2012 WR450 Throttle stop screw. You can go to ACE hardware, Lowes, Home Depot etc and find the screw. When you remove the throttle stop your basically just stick something in there to keep water, mud, etc from getting in there.
M5 x 7 is the YZ screw size.
If you don't want to purchase the ECU or you are waiting on it. Below is the throttle screw part number.
Appears to be a M5 x 7 socket head screw. I looked at Ace Hardware and they have M5 x 8 screws for 75 cents. So you would have to grind it down 1 mm. Looked like they did carry M5 x 7 but were out of them at the location I was at.
Didn't put a caliper or anything on these just eyeballed by comparison and holding them up to each other.
Part # 91317-05008
Edited by supermega1, November 14, 2012 - 02:28 PM.
  • William1
Posted November 14, 2012 - 02:32 PM
Not the same screw. The throttle stop screw is a special one, with about 8mm threaded near the head and then a smooth shaft with a rounded tip.
  • Chaddlez
Posted December 27, 2012 - 03:33 PM
William1
[color=#5A5A5A][font=helvetica, arial, sans-serif][size=3][background=rgb(252, 252, 252)]
[color=#777777][size=3]
Posted 15 November 2012 - 10:32 AM[/size][/color][/background][/size][/font][/color]
[color=#282828][font=helvetica, arial, sans-serif][background=rgb(252, 252, 252)]Not the same screw. The throttle stop screw is a special one, with about 8mm threaded near the head and then a [/background][/font][/color]smooth[color=#282828][font=helvetica, arial, sans-serif][background=rgb(252, 252, 252)] shaft with a rounded tip.[/background][/font][/color]any photos
Any photo's to confirm William?
