Quick question on jetting..
3 replies to this topic
  • Regenerex
Posted November 12, 2012 - 12:31 PM
Hey guys,
Tried searching, couldn't find anything, so...
After a trouble free season with my new WR (2011 leftover), I found it needs a little more power for next season. I am thinking about adding the Fmf Power/Mega bomb header, Powercore Ti Slipon, High flow filter, and drop a tooth on the front sproket. Anyway, with the Exhaust, and filter, what should I change my jetting to? I currently have stock jetting and all the free mods done. I live at Sea level, at around 20-30 degrees celsius.
Thanks.
  • Thommo_400f
Posted November 15, 2012 - 02:55 AM
Krannie told me:
More restricted = less fuel.
So
Less restricted means more fuel required.
So you may be a little lean. Assuming you are already correctly jetted.
Only tinkering will really tell ;)
Buy some jets and get into it.
  • MANIAC998
Posted November 15, 2012 - 03:44 AM
The easiest way would be to purchase the JD jet kit, and follow his directions to achieve a very well running machine with lots of power. Others will tell you to purchase a selection of jets from Yamaha, Carb warehouse, etc.. and through trial & error achieve the same thing. The choice is yours.
  • Regenerex
Posted November 15, 2012 - 10:12 AM
Thanks for the info guys, I'll be buying the JD jet kit soon. I got all winter before i'll really be able to see a power difference, but i'll at least know what to change it to.
Thanks again.
