Carb Problem?
4 replies to this topic
  • jcolborn48
Posted November 11, 2012 - 09:37 PM
I have a 2007 yz450, put in the JD jet kit, and Zip Ty fuel screw. Just bought a 2009 yz450f, and put the carb from my '07 into the '09. First ride on the 09 and the bike will stutter at lower rpms, and runs good with the throttle all open. 2 questions:
1: There shouldn't be a problem putting the 07 carb into the 09, right?
2: Could it just be fuel screw settings? I shouldn't have to re-jet it right?
Thanks in advance!
  • dunegoon112
Posted November 13, 2012 - 06:59 AM
do you have different mods on the different bikes or are they both stock
Posted November 13, 2012 - 12:05 PM
Did you move the TPS on the carb that is on the bike now?
  • alligatorman
Posted November 13, 2012 - 04:27 PM
Which JD needle and clip position?
Whats the engine run like at 1/8, 1/4, 1/2 throttle?
Best idea is to try adjusting the fuel screw out to a max of 2.5 turns out. If that doesn't work you may need to go one size up.
Edited by alligatorman, November 13, 2012 - 04:28 PM.
  • jcolborn48
Posted November 13, 2012 - 08:27 PM
Both bikes had stock motors, only difference is the 07 had an FMF pipe, and the 09 has a pro circuit. TPS was not adjusted when changed. In terms of 1/8, 1/4, 1/2 throttle, all I can say is that the more open the throttle the better it runs.
I'm going to play with the fuel screw and see what that does. Thanks guys!
  • Hot  106 replies
  • Hot  36 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  79 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
