DRZ 400E exhaust
9 replies to this topic
  • BBouncer5150
Posted November 11, 2012 - 04:56 PM
I own a new 2012 DRZ400s and have been looking around for an exhaust that I don't have to repack and decided that a stock E model full exhaust would be the best way to go. I found a good price on an '05 rear can and now will need to purchase a E header. Can I get a new '05 header through my local Suzuki dealer or through an online source? Also, I've learned through reading multiple posts on this an other sites that the mid-pipe mount is slightly different and that I'll have to mount it through one of the rear foot peg mounts. Are there any other mounting issues I need to be aware of?
  • Craigo
Posted November 12, 2012 - 02:43 AM
No other issues I am aware of...Used E head pipes often appear on Ebay...
You could also try the TT store for new.......
https://www.thumpert...2004&model=5309
  • BBouncer5150
Posted November 12, 2012 - 12:31 PM
I picked up a very good condition stock can for $40 the other day from a parted out '05 and now I just need the header pipe. I couldn't find anything on Ebay, but found two sites that sell new OEM Suzuki parts and they list the header as available so I think I'm going to just go the stock route.
  • lowercasee
Posted November 13, 2012 - 05:02 AM
Don't forget to check the classifieds on TT. That's where I got my E header for a great price. You can actually use the S/SM muffler, which is apparently the same internally as the E muffler in the US, with the E header with a simple mod. Here's a link:
http://www.thumperta...th-ssm-muffler/
  • DrzDick
Posted November 13, 2012 - 06:16 AM
I fitted an S subframe on my E and had lots of mid pipe mounting point issues.
My bike an E, front pipe standard, rear is DEP. The fitted was pretty good on the E sub-frame (as you'd expect) but a PITA on the S.
Not only was the hole in the wrong place it's also too far inwards so was pushing the pipe into the rear spring - be prepared to have to dent the pipe to stop it fouling on the spring. It's also a little too far back so opens up the gap where your pipe join - that may just have been because of my pannier attachment part though.
Either way it can be a real PITA.
Next time I fit the S subframe I may pick up a used S rear pipe as well.
  • BBouncer5150
Posted November 13, 2012 - 06:50 PM
Thanks Dick, I'll take a look at the forums before I buy a new header. As to the mounting, I intend to fab a bracket of some sort and maybe install a spacer if needed to get it to mount up. I was initially going to go with a LV or FMF, but don't want to deal with the packing so I thought the stock E exhaust would be the best route for me.
Anyone have pics of their S model with an E exhaust so I can get an idea of what I'll need to do?
  • BBouncer5150
Posted November 13, 2012 - 06:56 PM
Lowercasee,
I read the post, but want to keep my stock exhaust intact in case I ever decide to put it back on.
  • DrzDick
Posted November 14, 2012 - 04:45 AM
Some of my older threads that might interest you.
http://www.thumperta...1#entry10080323
http://www.thumperta..._1#entry9987326
Good tip here - use a washer to space the subframe out.
http://www.thumperta..._1#entry9922410
Edited by DrzDick, November 14, 2012 - 04:45 AM.
  • BBouncer5150
Posted November 14, 2012 - 09:37 PM
Thanks for the links Dick. This looks like a much bigger job than I initially thought! I guess I'll have to rethink this...maybe a trip to the muffler shop with my standard S exhaust is in order, or leave it alone and just do the rejet and 3x3..
  • Bedunjgi
Posted November 15, 2012 - 11:38 PM
I have a full setup with E header, heat shield, slip joint & S silencer in decent condition for sale but it ships from 96815 (Honolulu). I might consider selling just the header.
Drz400E aus spec E and mrd exhaust by GearHeadGumbie
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
CRD HEADER and STOCK S SILENCER? by Alex Wilford
I think I am too stupid to install throttle cables... by razzledazzle
  • Hot  46 replies
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
