Countershaft sprocket is the real deal(and other assorted thoughts)
3 replies to this topic
  • RayCharles
Posted November 02, 2012 - 07:10 PM
Hey, moved the 15 tooth to a 14 tooth on my DRZ400S tonight and just wanted to comment that the nut was in fact terrifyingly loose, and any new owners (such as myself) should definitely heed the loctite warning. The nut itself came off with a little bit of applied pressure and a handheld wrench. No impact gun, no breaker bar, no holding the rear brake. Additionally, if any of you are curious the 14 tooth sprocket actually comes in handy from what I can tell so far. It makes 3rd a useable around town cruising gear (it was pretty luggy for me originally and I would often have to swap between 2nd and 3rd riding through town). Oh also it makes the front end jump up pretty quick, if thats what youre looking for.
While Im at it, I set my chain sag with the kickstand down and the bike on the floor @ 1.5-2 inches like I read elsewhere on the forum, is this normal for the rest of you?
  • NEKOOHC
Posted November 02, 2012 - 07:42 PM
I use 3 fingers between the chain and Behind the swingarm buffer , at the chains tightest point
  • chevybowtieguy
Posted November 13, 2012 - 04:48 PM
yeah i just realized i have been running mine too tight. looked okay sitting in the garage on the kickstand, but when i sat on it and the swing arm levels out a bit the distance between the front and rear sprockets increases and tightens the chain up really tight. so its always good to check it with the suspension loaded to make sure its not super tight while at ride hight.
  • RayCharles
Posted November 13, 2012 - 05:03 PM
Agreed. After I posted this I checked it again under full load and it was still binding so I let it out one more notch. Its riding nicely now!
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
Desert SuperMoto by alpha_nett
  • Hot  60 replies
CRD HEADER and STOCK S SILENCER? by Alex Wilford
Upgrading from S to SM forks and rear axle worth it? by arpuS
  • Hot  50 replies
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
  • Hot  56 replies
