Valves and hours?
Posted 26 October 2012 - 01:47 PM
Regards,
Dewking
Posted 26 October 2012 - 02:43 PM
Posted 26 October 2012 - 03:36 PM
Edited by jcross312, 26 October 2012 - 03:37 PM.
Posted 26 October 2012 - 05:06 PM
Posted 27 October 2012 - 06:01 PM
Posted 27 October 2012 - 06:12 PM
*plus the 5 hours or so I put on before the hour meter!
Edited by gotwings, 27 October 2012 - 06:13 PM.
Posted 27 October 2012 - 08:19 PM
It's best to replace them as part of preventive maintenance , if the valves fail expect a ruined motor at the least
Posted 28 October 2012 - 05:26 AM
Honda valves typically lose their surface hardening and start to recede into the head long before they are old enough to break. That's actually a good thing because the bike just gets hard to start when the valve is worn, which gives the CRF owner some warning.
Yamaha gets high praise for how long their valves last, but that's a double edge sword because people can run them so long that eventually a valve head breaks off and wipes out the engine.
Posted 28 October 2012 - 06:26 AM
In your opinion, at what hour mark would you replace valves as preventative maintenance?
Posted 28 October 2012 - 07:13 AM
jcross312, on 28 October 2012 - 06:26 AM, said:
That depends on how you ride. If you are a pro mx'er, I'd replace them when I replaced the crank, which would be every 50 hours. I you are in the normal 99%, I'd run them until they required the first shim job. If you replace them instead of shimming them, you typically don't need to grind the seats. The exception is when the seat isn't concentric, which shows up when the valves wear out under 50 hours.
Posted 28 October 2012 - 07:22 AM
jcross312, on 26 October 2012 - 03:36 PM, said:
Posted 28 October 2012 - 04:28 PM
ljschnel, on 28 October 2012 - 07:22 AM, said:
Do yourself a favor and replace the valves/springs before you ride the bike again. Right now, the seats are probably still good, but if you continue to ride with worn out valves, the seats will be ruined too. Shim jobs only last a few hours on Ti valves and they wreck the valve seats in the process.
Replacing the valves/springs now will save you $150 in seat grinding later.
Edited by CamP, 28 October 2012 - 04:34 PM.
Posted 28 October 2012 - 05:48 PM
I will have to agree, I just put new steel intakes in my bike after shimming the ti's one time and I am very pleased with the outcome.
Posted 28 October 2012 - 09:06 PM
jcross312, on 28 October 2012 - 05:48 PM, said:
Posted 29 October 2012 - 06:26 AM
ljschnel, on 28 October 2012 - 09:06 PM, said:
Yes, at 208 hours, it's time to replace the piston/ring/wristpin. A ball hone will take off the cylinder glaze, but you can use scotchbrite to do the same thing.
Posted 29 October 2012 - 06:36 PM
Posted 30 October 2012 - 09:41 AM
Edited by Dirtclods, 30 October 2012 - 10:46 AM.
Posted 30 October 2012 - 02:48 PM
Mine stretched when I baked the bike.
The only issues I have had are difficultly starting...adjust the valves and its happy again. Im on my 3rd and final adjustment...its time for new valves.
Edited by meeh350, 30 October 2012 - 08:26 PM.
Posted 30 October 2012 - 06:42 PM
