Need help getting the front sprocket off
10 replies to this topic
  • vomitbomb
Posted October 25, 2012 - 12:03 AM
Hi All,
The 2010 yz450 isn't reverse thread is it? I didn't think it was.
I've tried putting a block of wood between the spokes and the swing arm - still no luck. I just installed a Rekluse so I can't use the gears, doh!
Short of harnessing the power of the sun, what else can I do?
  • 72degrees
Posted October 25, 2012 - 12:12 AM
Asssuming it's like earlier YZs. Make sure the locking washer is *absolutely* flat. Soak the nut/shaft with penetrating oil and be patient for a while. Spokes are a bit springy. Try a u-bolt or similar (I use a pipe spanner) through one of the rear sprocket slots/holes if there are any to jam against the swingarm. Use a long 'breaker bar' and well fitting socket. If that fails try to beg, borrow or steal a 'rattle gun' (air impact driver)/compressor and a perfectly fitting 6 point socket.
  • STR8SHOOTR
Posted October 25, 2012 - 02:31 PM
impact gun is the easiest way,after you get the lock washer flat
Edited by STR8SHOOTR, October 25, 2012 - 02:31 PM.
  • High_Boost
Posted October 26, 2012 - 05:56 AM
I second the impact.. I tried and tried, I used a big long breaker bar with a cheater bar on it, I let it soak for a day with penetrating oil.. it just felt like something was going to break
so I took it to work and used an impact and it spun right off, no sweat
if you dont have access to one, load the bike up and go to a tire shop.. one of the guys in the back would be happy to do it for a couple of buck tip
  • cereal killer
Posted October 26, 2012 - 06:53 AM
A shortcut that sometimes works when you don't have access to an impact gun is just to hit the end of the wrench with a big hammer. Hard.
  • STR8SHOOTR
Posted October 26, 2012 - 10:35 AM
I have a battery powered Milwaukee 1/2 drive impact bought it on AMAZON. One of the best tools I own for MX and Auto repairs. I don't have room for a compressor and air tools right now, so this works well for me.
  • frankie_b_jr
Posted October 26, 2012 - 07:56 PM
I use a bungee cord (a good black one) hooked on the brake pedal, going under the frame, then hooking to the subframe. It locks the back brake solid and saves spokes and spocket mounts.
  • cereal killer
Posted October 27, 2012 - 05:47 AM
That's a good idea too, except instead of a bungee cord you can just push the pedal down and stick a screwdriver through the swingarm bolt. Don't know why I didn't think of that until you mentioned the brake pedal, but it's how I keep the clutch basket steady while I tighten the pressure plate bolts.
  • Jonnoh
Posted December 08, 2012 - 06:15 PM
Dont bother with the bungee or screwdriver. Assuming the bike is on a stand, just get on the bike and push the rear brake down with your foot and reach down and loosen the nut with your socket wrench. It doesn't get any easier (unless you have the impact wrench ready to rock)
  • frankie_b_jr
Posted December 09, 2012 - 09:30 PM
If you're fat and lazy like me you don't climb on and off any more than necessary :-)
  • FinchFan194
Posted December 10, 2012 - 09:06 PM
If it is being REALLY stubborn you may need to stick a small block to tension the chain in between the chain and the swingarm. I have had this problem before and my impact wrench wouldn't touch it, the chain was allowing the front sprocket to shake around too much, as soo as I tensioned it up with a chunk of wood, it slowly spun off.
  • Hot  28 replies
  • Hot  47 replies
  • Hot  38 replies
  • On January 15, 2017
