2011 wr450 wire connectors
2 replies to this topic
  • medicman
Posted October 24, 2012 - 03:29 PM
So aim trying to remove the subframe on my bike, the wire connectors are a pain. Is there a special tool to push both pins in at the same time or do you just have to be very coordinated
  • MANIAC998
Posted October 24, 2012 - 06:04 PM
You can get them by hand. Sometimes it helps to push the connector together before pulling them apart. This allows the little pin that's holding them together a chance to dis-engage. When you go to put them back together, use dielectric grease, and you won't believe how easily you can remove them the next time!!! :thumbsup:
  • William1
Posted October 25, 2012 - 08:58 AM
I often use a jewelers screw driver to press the tab in too.
