Can I slide the forks up (and how far) on the 2012 YZF 450?
5 replies to this topic
  • broncomoto
Posted October 22, 2012 - 03:52 PM
Can I slide the forks up (and how far) on the 2012 YZF 450? Bronco
  • bigj450
Posted October 23, 2012 - 02:22 AM
i got mine slid up 5mm, dont see why ya couldnt go further, depends wat ya lookin for i guess
  • YamaLink
Posted October 23, 2012 - 05:31 AM
As stated, depends what you're looking for. Make sure rear sag is set first before fine tuning the fork height.
Posted October 23, 2012 - 05:53 AM
The limit to how far you can move the fork up in the clamp is defined by the outer fork tube. Looking at the portion that fits into the clamps, you'll see how far below the clamp the area machined to match the clamp extends. When they've moved up to the end of that, that's the limit. You may also find that contact with the handlebars may limit the upward movement.
There are two lines scribed on the tops of the tubes, 5 and 10mm from the top. Use these for reference, or measure them to match. Having both of them absolutely matching is not critical beyond a couple of millimeters, but get them close to the same height. I run mine up 14mm, but it's an '06.
  • dfinn
Posted October 23, 2012 - 09:19 AM
can't hurt to play with it (what she said) but I've read/heard several things that seem to say that this bike rides best with the forks flush with the top crown.
  • Stu2
Posted October 24, 2012 - 02:16 AM
Mine is best with the forks flush, if its turning your looking for, make sure your bars are in the forward position, makes all the difference
  • Hot  33 replies
Need help by Goforaride
  • Hot  68 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  79 replies
