2012 YZ450F Oil Filter
8 replies to this topic
  • tomjoens
Posted October 18, 2012 - 03:28 PM
Can somebody change the oil on there 2012 yz450f and take a pic of which way there oil filter goes back on?
Posted October 18, 2012 - 04:18 PM
Why? It absolutely goes in hole first.
  • Ben Mens
Posted October 19, 2012 - 08:24 AM
I've never tried....butttttttttt I'm pretty positive it'd take a lot of force (or the wrong filter) to put it in/on the wrong way.
Posted October 19, 2012 - 09:08 AM
I know that in previous years (prior to the '10), it was impossible to put the filter in backward without crushing it to 2/3 its original length. I would assume the same thing is still true.
  • MX763
Posted October 19, 2012 - 11:30 AM
There is a hole on one side of the filter and the other end is closed. There is a piece of aluminum sticking out of the case which leaves only one way for it to go on.
  • tomjoens
Posted October 19, 2012 - 12:16 PM
No the closed end has a spring on it so that if it's starts cold the oil still is allowed to pass and if the filter gets cloged it will still allow oil to pass through. You can put it in backwords.
You can push the spring in about a half inch if i knew how to post pictures I have a bunch and could show.
  • Ben Mens
Posted October 20, 2012 - 09:05 AM
Are you sure you own a Yamaha?
  • bigj450
Posted October 20, 2012 - 01:50 PM
are you talkin bout a aftermarket oil filter, or a stock yamaha filter........??
Posted October 21, 2012 - 07:39 AM
He's talking about the bypass valve on the closed end of the filter, and the fact that he is apparently able to jam the safety tab in the case into that hole by inserting the filter backward. Maybe, but if it's anything like the '09 and earlier models, you'd still have to try really hard to install it inside out.
