BK carb mod?
2 replies to this topic
  • freeh717
Posted October 16, 2001 - 02:07 PM
I just installed a screw for the mod, but it seems a little loose. Is this normal or should it be tight? I am using two springs like mx393 shows in his pics. Also, the cover must be modified to fit over the screw correct? I could tap a larger screw hole, but there wouldn't be much material left in the boss area. Any suggestions would be greatly appreciated. Thanks.
  • yzernie
Posted October 16, 2001 - 02:35 PM
I used blue lock tite because mine seemed the same way. The spring does not feel like it adds very much tension. The cover needs to be modified. I would be careful about going larger on the hole. Like you said, there isn't much room there.
Ernie
--Life is too short, work hard...play hard--
Sponsored by Yamaha of Cucamonga, Larry Roeseler's Stroker Fourstroke Speed Equipment and Answer Racing, yzernie@dirtracers.com
  • motoman393
Posted October 16, 2001 - 04:57 PM
Mine was real loose too (due to a not drilling straight...my fault) I packed the hole with JB weld and let it dry then I retapped it and now it is tight (the springs help if you get a strong one)! Or you can use teflon tape for a quick fix. Once you get the screw set where you want you probably wont ever have to change it so you can use loctite also. Hope this helps,
Garrett http://mx393.tripod.com/carb.html
I get my kicks on a 426!
Motoman393's MX Site
  • Hot  38 replies
  • On January 15, 2017
  • Hot  47 replies
  • Hot  113 replies
