Brakes Make A HUGE Difference...
16 replies to this topic
  • JB-250
Posted 13 October 2012 - 09:30 PM
my brakes are pretty new but they got oil and fluid all over them and will not grab anymore...my friends 250 stopped INSTANTLY as i tapped lightly...
so i am looking for new pads and i see a list of different types and models...
for an 01 cr250 i see some that are
full padding no cuts in them
full padding with cuts
carbone lorraine
ceramic
kevlar carbon
semi metalic
severe duty
sintered
why so many types and what is the difference if one has cuts in them? i noticed some are recangular, some are curved rectangle, some are square, and some are just longer rectangles...which do i get they all say 95-01 cr250 brake pads..
please help me...
  • CamP
Posted 14 October 2012 - 06:37 AM
The OEM brake pads are best.
  • mynewcr250
Posted 14 October 2012 - 07:46 AM
im willing to bet, half the pictures you saw were "stock" photos, IE: not for your application, just a photo to show what they're selling
either get OEM (they're cheap) or get a pad that matches OEM. ive leared one thing, when dealing with pads, the OEM are usually of higher quality.
  • BRAAAAAP424
Posted 14 October 2012 - 07:58 AM
I was using a sintered brake pad on my 03. But if i ever got a little chain lube on it, or some mud it just quit grabbing.. i would go with oem.
  • JJRace
Posted 14 October 2012 - 08:00 AM
check www.crfstuff.com
lots of info, parts and tips there for you
  • Team Buggerall
Posted 14 October 2012 - 08:06 AM
Um, your wasting your money on brake pads man, you need a fork seal kit first !
  • CamP
Posted 14 October 2012 - 08:07 AM
You can clean your oily pads by soaking them in paint thinner.
  • YHGEORGE
Posted 14 October 2012 - 08:51 AM
And unless Honda has changed things, the oem pads from an XR4 will fit and are thicker. They last much longer and handle heat better.
  • JB-250
Posted 14 October 2012 - 02:47 PM
i am replacing my seals
I think going for sintered pads front and rear $16? but are they really bad when wet? i will be riding all season and want to have good brakes that last for some time...
  • Hondude450
Posted 14 October 2012 - 08:18 PM
Oem pads are the best for all conditions. used ebc pads for a while. going back to oem pads.
  • JJRace
Posted 15 October 2012 - 06:23 AM
keep in mind aftermarket makes different compounds for different uses.  Now if you select the wrong compound, then ya you wont be satisfied.  Same thing with automotive brakes.
pick the right compound and it will be an improvement over stock.
  • Red4Life
Posted 15 October 2012 - 02:40 PM
wow, ill have to give this a try, my fronts got some fork oil on them and now they are suuuper soft, and dont do much at all really. thanks for the tip :thumbsup:
  • Hondude450
Posted 15 October 2012 - 09:44 PM
Yes I agree. but if you ride in alot of different condition stock pad, seem to work the best, for me. thats all i was saying.
  • JB-250
Posted 17 October 2012 - 10:19 PM
i dont have any connection to getting oem brake pads for awhile so i am tempted to just go for the sintered HH pads...i wanted oem but none have them yet...
only bad thing i read is sintered is harder on ur pads and can really damage your entire braking system (eg caliper, piston) is this true? what are the bad from these pads?
  • farfromhome63
Posted 17 October 2012 - 10:50 PM
even cleaning pads didnt work for me.. a set of ebc reds and sanding the crap outa the rotor fixed my issues.. oem new pads still in toolbox..
  • YHGEORGE
Posted 18 October 2012 - 08:02 AM
Breaking the glaze on the rotor probably was the key.
  • DHS_sponsored
Posted 18 October 2012 - 01:34 PM
AP racing ORR, as per CRFstuff.com hands down the best pads I have used, in any condition, great feel, great power, great quality, pretty decent life span and cope with the heat too, i ride my rear brake at times, and with OEM, and some other brands i would get some fade. I have never experienced this with the AP's.
