Acerbis hand gaurds
2 replies to this topic
  • Shock_Doc
Posted November 10, 2003 - 09:41 PM
Any one know off hand what bolts to use on clutch/brake perches when changing hand gaurds on the BRP?
Thanks
  • stonewall
Posted November 10, 2003 - 09:54 PM
If you are talking about replacing the long bolts with shorter ones these part #'s should help. The shorter bolts make things look more sano and prevent your fingers from getting mangled. :)
Brake Lever Bolt - part #90114-166-006
Brake Lever Boot - part #53176-ML3-791
Clutch Lever Bolt - part #90114-428-870
Clutch Lever Boot - part #53177-430-000
  • Shock_Doc
Posted November 10, 2003 - 10:04 PM
way cool....thank you. Going to change hand gaurds before I leave for the baja 1000.
