Hole in engine
Yes, that hole allows any moisture to drain out of the space around the spark plug. If it was not there, pressure would build from the heat and push the spark plug lead off. Plus, this hole is handy for blowing debris from the spark plug before you change it. Just remove the lead and use compressed air and shoot it thru that hole and watch all the trash that comes flying up. Protect your eyes. You can also use a shot of air to push the plug lead up about an inch so that you can get a grip on it for removal. I'm beginning to get a bit of arthritis in my fingers and can't use them like I once could, so any help is a good thing.
