Piston Installed backwards?
1 reply to this topic
  • ILOAD2
Posted October 07, 2012 - 06:50 PM
If the piston was installed backwards on the Yamaha 5 valve motor,would the 3 intake valve buckets depress fully and smoothly as I hand crank the motor via the 17mm nut on the rotor? Or would it lock as the center intake valve depressed?
  • highmarker
Posted October 07, 2012 - 07:04 PM
most likely hit the piston but never tried it, if your not sure pull it apart or maybe use a bore scope like used for checking wash on a twostroke to look through the plug hole.
