low rpm problem
5 replies to this topic
  • gal
Posted October 13, 2001 - 08:25 AM
hi there
when i ride my 2000 yz426f on low rpm, the engine turns off. its only low speed, specialy when i ride on rocks - so i have to ride with half clutch and it kills my arm n my clutch. is there anything i can do?
i ride 15/49 and stock jettings . the bike runs great. at the beggining i tought it was my bad riding but i asked two of my friends to ride it and they had the same prob. what should i do?
  • gal
Posted October 13, 2001 - 08:27 AM
just to clear things up - its only when i ride rocks n tight enduro's...
  • sirthumpalot
Posted October 13, 2001 - 11:44 AM
Is it stalling because the engine RPM just gets to low (lower than idle)? Does it stall while you're going a steady speed, or when you give it gas to speed up?
The yz has a very tall first gear and it's tough to go really slow without stalling. I'm wondering if this is what's happening with you.
  • Boit
Posted October 13, 2001 - 04:29 PM
Plus, you've made 1st gear even taller by adding a tooth to the countershaft. 14/49 is stock. If you are riding in very slow conditions you would probably see an improvement if you went to something such as 13/50 and adding a flywheel weight. Make sure your engine is in a good state of tune.
  • gal
Posted October 14, 2001 - 09:27 PM
YES SIR THUPMALOT, THATS MY PROBLEM CAUSE IM A BIT SCARED WHEN I RIDE ON ROCKS....
ILL GIVE 14/50 A TRY
WHAT FLYWHEEL DO U RECCOMEND AND WHERE CAN I BUY IT FROM (AN ONLINE SHOP OR SOMETHING)
THANKS
  • Boit
Posted October 14, 2001 - 12:56 PM
You can try E-Line and/or Zip Ty and maybe IMS. The WR side of this forum has threads concerning flywheel weights. Seems like 10oz. is about the most popular weight.
