2010 Shock Service
1 reply to this topic
  • BBrown626
Posted September 27, 2012 - 08:14 PM
I serviced my shock today. If you service your own, how are you removing the bladder cap? Previous models had the schrader valve attached to a block on the cap and you pulled on that block to remove the cap. The new cap has nothing to grab. I carefully pulled on the schrader valve with it capped and that worked. I thought I might be able to apply some compressed air to pop it out, but my hand pump was having some trouble today.
I cleaned mine all up and filled it with some fresh motul shock fluid. No changes were made to the internals. Are there any recomended improvements to the valving that I should perform the next time around?
thank you,
Brent
Posted September 28, 2012 - 08:21 AM
Every YZF shock (for that matter, every KYB) I've done has benefited from beefing up the face of the rebound stack considerably. The '10 benefits from a little bit of modification to the comp stack, too.
I used a setup I got from SPI on a '10, and the owner was pretty happy with it. Probably not the end all ultimate stacks, since no two people are the same, and since it was a year and a half ago, but here it is. Bold are the shims that were changed:
Rebound:
40 x 0.30 x 12
40 x 0.30 x 12
40 x 0.30 x 12
40 x 0.20 x 12
40 x 0.20 x 12
40 x 0.20 x 12
29 x 0.11 x 12
40 x 0.30 x 12
38 x 0.30 x 12
36 x 0.30 x 12
34 x 0.30 x 12
32 x 0.30 x 12
30 x 0.30 x 12
28 x 0.30 x 12
25 x 0.30 x 12
28 x 3.00 x 12
Compression:
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
44 x 0.20 x 12
36 x 0.15 x 12
32 x 0.15 x 12
44 x 0.20 x 12
44 x 0.25 x 12
42 x 0.20 x 12
42 x 0.25 x 12
40 x 0.25 x 12
38 x 0.25 x 12
36 x 0.25 x 12
34 x 0.25 x 12
32 x 0.25 x 12
30 x 0.25 x 12
29 x 0.25 x 12
28 x 0.25 x 12
27 x 0.25 x 12
26 x 0.25 x 12
25 x 0.25 x 12
24 x 0.25 x 12
23 x 0.25 x 12
22 x 0.25 x 12
21 x 0.25 x 12
41 x 4.50 x 12
Exchange ("high speed") valve not modified
  • 0 replies
  • On Yesterday, 06:20 PM
  • Hot  113 replies
  • 10 replies
