Drz400s wheel on SM
2 replies to this topic
  • Barb_87
Posted 27 September 2012 - 05:31 PM
The S wheel is it fit on the SM or it need some modification?
  • alexgauthier
Posted 28 September 2012 - 11:03 AM
If they are both factory wheels they will interchange.
  • JEB1962
Posted 28 September 2012 - 04:14 PM
Yes they will transfer right over but you will need to put SM rotors onto the S rims. The SM chain is two links shorter BTW, but will probably not be a problem with the 44 tooth sprocket on a S rim. The speedometer, odometer will be off unless you use an S model gear on the front rim  and the SM kick stand will be a little short.
Edited by JEB1962, 28 September 2012 - 04:17 PM.
