2007 power flat, jetting?
I recently rebuilt my 2007 yz450f. Had the head redone with stainless valves, springs and polished up. I also installed a High compression piston 13.6 : 1 and new timing chain. Starts first or second kick but the power feels mushy and flat. Im thinking the power should be crispy and pull super hard. I have a 165 main 48pj and stock needle in the stock position, 3rd. Stock exhaust back on. Im under 0-2500 feet in Northern Cali. Im thinking of trying a 170mj and maybe the needle in the 4th clip?
Pull the top engine mounts to access the needle. Remember that the needle (the taper and height) is most effective between 1/4-3/4 throttle.
The recommendation for a 160 seems wrong given that you said the 162 made it worse. 45 pilot sounds right, though.
One of the effects of higher compression is that the intake signal gets stronger, especially at low speeds, so quite often raising the compression can make low speed jetting richer than normal. On top, it can work the other way 'round since the high RPM intake volume was good in the first place, and the extra compression can make the original jet seem too small.
Check to see if you have anything sitting in front of the main air jet passage at the mouth of the carb that could upset the balance.
You have to get the main and pilot jets at least in the ball park first. The needle is more of a trim adjustment thing, and only affects part throttle operation. The '06 ran an NFPR needle, which is the same major diameter and the same taper, but the taper is higher on the needle by half the difference from one groove to another. That means that NFLR-4 is one half step leaner at half throttle than an NFPR-4. Very small difference, but it validates the idea of trying NFLR-5.
But do the main and pilot first before you confuse the matter by changing too many things at one time.
