1/4 throttle blues
9 replies to this topic
  • pman1
Posted November 09, 2003 - 01:06 PM
Does any one have problem with 03 wr 450 at 1/4 throttle? Mine runs very rough. tried moving clip up and down. Each way makes it worse. Changed pilot jet each way. Each way is worse. Also I never recieved anything about a recall from my dealer. Does it only affect sertain serial no.s or is my dealer letting me down. Please Help!!!!!!!!!!!!
  • Jim_bo
Posted November 09, 2003 - 04:29 PM
I had a problem with mine surging at 1/4 throttle. I got a YZ450 needle for my carb and it fixed it right up.
Jimbo
  • racemile
Posted November 10, 2003 - 10:32 AM
I know that on the 426, that area of the throttle was controlled by the pilot circuit....is this different on the 450's?
Race
  • WR450F_RDR
Posted November 10, 2003 - 02:29 PM
If you havent tried the James Dean needle kit that is what I would suggest, overall this made the most improvement in low end response on my bike.
  • lipskid
Posted November 10, 2003 - 02:51 PM
Pman- Mine was the same, grey wire mod fixed it.
  • Jim_bo
Posted November 10, 2003 - 03:19 PM
I tried the YZ needle because it is a richer needle than the WR. Mine surged a lot at about 1/4-1/3 throttle. I took it up to the mountains (about 7000 ft) and the problem went away. I then knew I had to richen up. Worked for me and it was only about $10 and 15 minutes to install.
Jimbo
  • Indy_WR450
Posted November 10, 2003 - 04:24 PM
JD kit is worth every Penny for a WR! Best needles around.
  • pman1
Posted November 11, 2003 - 07:21 AM
thanks everyone. Will try needle and cut grey wire. If
That doesnt work will get JD kit.
pman
  • WRer
Posted November 11, 2003 - 06:54 PM
I have the same problem with the WR450 is there a dead spot when you crack the thottle quickly also
  • pman1
Posted November 12, 2003 - 09:33 PM
no dead spot just doesnt run smooth at about 1/4 throttle
