06 yz 450 Crank Question
3 replies to this topic
  • STR8SHOOTR
Posted September 26, 2012 - 03:09 AM
I did a top end nik the cyclinder, piston&rings timing chain. I noticed that the crank had alot of heat indication were the rod connects to the crank at the bearing (discoloration), I was wondering if this was normal? The rod had no play up and down and very slight side to side and rotated smoothly.
Edited by STR8SHOOTR, September 26, 2012 - 03:10 AM.
  • Dougie64
Posted September 26, 2012 - 03:37 AM
Piiiccctttuuurrreeesssss
Posted September 26, 2012 - 08:11 AM
The heat bluing around the crank pin is a result of the original manufacturing process. The procedure for measuring bearing/pin wear is outlined in the manual. A dial gauge is used to measure the amount that the small end of the rod can be rocked side to side without the big end sliding on the crank.
  • STR8SHOOTR
Posted September 26, 2012 - 04:32 PM
Thanks again Gray!
  • 0 replies
  • Hot  50 replies
  • Hot  47 replies
