Loc - tite on rear axel bolt?
4 replies to this topic
  • Bryan Bosch
Posted April 23, 2001 - 10:31 AM
Dirt Bike magazine said not to put loc tite on axles, however, there is not a castle nut and cotter pin on the dub-r and my axle nut has loosened after a few rides. Did I just not torque the nut tight enough? Are you using loc tite?
[This message has been edited by Bryan Bosch (edited 04-23-2001).]
  • Scott_F
Posted April 23, 2001 - 10:47 AM
Torque it to 60 pounds and it should not come loose.
  • Guest_Guest_*
Posted April 23, 2001 - 04:14 PM
I torque mine to 90 ft/lbs, and have not had a problem. ~Hit-man~
00' yz426f LATER DAYS!!!
  • MS
Posted April 23, 2001 - 04:43 PM
Bryan:
No problem with my WR axle bolt coming loose, but I have experienced loose Sprocket bolts, that I check every ride and have now lock tited...
MS.
  • Greg_C
Posted April 24, 2001 - 04:22 AM
Mine was getting loose all the time almost after each ride. I just had to replace the axle and nut so I haven't had a chance to find out if it is still happening.
