van question, yes I did search
Posted 21 September 2012 - 01:15 AM
Posted 21 September 2012 - 04:11 AM
Posted 21 September 2012 - 05:32 AM
Posted 21 September 2012 - 09:17 AM
Posted 21 September 2012 - 02:00 PM
MasterCraft
Setra 200B
Posted 22 September 2012 - 03:20 AM
Posted 23 September 2012 - 02:45 PM
Posted 23 September 2012 - 04:03 PM
Also, you have to be mindful of the corrugation of the floor. Try to keep your holes and bolts on the top flat sides of the raised ribs. If you get them on the bottom or the transitions things can get kinda funky and crooked.
To cover the side windows, get some thin plywood that can bend and follow the curve of the wall. Then you can screw it to the wall with short self-tapping screws. Just make sure they are short enough that they don't touch the outer skin or poke through to the outside!!!!!!!
I wouldn't rip out all the interior. That stuff keeps a lot of the road noise down and provides some insulation. Just take out what you need to.
Posted 24 September 2012 - 01:14 AM
Posted 26 September 2012 - 06:49 PM
Good Luck!
Posted 28 September 2012 - 01:47 PM
With an Extended Ford van you should EASILY be able to fit the 2nd row bench (behind captains chairs) and your bikes inside. I use the seat frame and eye bolts thru the fender wells to tie my bikes down. Works great. Also, if all the seats are there, put the 4 passenger rear seat in the second row, this gives you the longest seat for sleeping, more passengers etc. You will thank your self in the future for doing this.
PS My thoughts on tie downs for the bikes in the back of the vans, is to use turn buckles to the foot pegs and tighten. Also I don't use any type of tire shoe, I turn the bars so that the tire is between the wall and seat, I can fit 3 full size bikes this way.
Edited by 6 Riders, 28 September 2012 - 01:47 PM.
Posted 24 October 2012 - 07:51 PM
Posted 25 October 2012 - 11:52 AM
joe_joe, on 24 October 2012 - 07:51 PM, said:
I'm trailering a bunch of bikes right now, so I don't load the bikes into the van very often anymore, but I will take a picture next time I do.
BTW this is done in a STANDARD length '95 Chevy passenger van (old body style, 12 passenger), so it should be do-able in any "modern" body style van.
