2009 yz450 clutch basket removal
8 replies to this topic
  • diamonddave66
Posted September 18, 2012 - 12:54 PM
I have a 2009 yz450f and doing a complete clutch, basket, plates, inner and outer hub . Can the clutch basket be removed from the smaller side cover or do i have to remove the large cover ? Any tips or suprises i should know ?
Posted September 18, 2012 - 01:44 PM
It's a little trickier that way, but yes, you absolutely can do the job through the clutch cover while the crankcase cover remains in place. If the bike was run for a minute within a half hour of starting the job, very little oil will be lost doing this work with the bike upright; it's a dry sump.
  • You'll need a means of removing the main shaft nut, such as an impact gun or a holding device
  • Tapping the end of the main shaft inward can help free the boss if it gets stubborn
  • Be sure to remove the splined washer behind the boss or it will hold the basket on the shaft
  • Reinstalling: The small gear in the back engages two gears, the starter idler and the oil pump idler, while the driven gear has to mesh with the crank. Be Patient.
  • flapwick
Posted September 18, 2012 - 04:43 PM
Just did my 07.Gray basically has it covered.I just removed the round plate and used a vice grip looking basket holder from TUSK.Really easy to remove the nut with this tool holding the inner basket in place.Torqueing it to 54 pounds was no sweat either upon reinstallation.Gray is right,it was just a little bit tricky putting the basket back on and I kept wondering why I didn't have as much thread for the nut...it took a few tries to finally get the gears in sync and then it slid into place like butter.Just keep playing with it,and it's obvious when it's right.My nut is a 30mm,by the way,I suppose yours is too.Have fun!Oh,and be really careful to keep track of that single ballbearing at the end of the push rod....okay,now look inside the other part....
  • diamonddave66
Posted September 18, 2012 - 04:44 PM
Thanks for the info.
  • stroker101
Posted September 18, 2012 - 08:53 PM
" very little oil will be lost doing this work with the bike upright; it's a dry sump. "
laying the bike (clutch side of the handle bar) on your bike stand or something equivalent in height, will allow you to perform your work w/o any oil spillage. but if your installing new clutch components, why wouldn't you just change the oil also?
Posted September 19, 2012 - 06:25 AM
...if your installing new clutch components, why wouldn't you just change the oil also?
Sometimes it works out that you just did that already. :excuseme:
  • psylo535
Posted September 24, 2012 - 03:00 PM
Pretty sure I gave you the answer to this question before this post, but what do I know !
  • diamonddave66
Posted September 27, 2012 - 04:54 PM
You probably did but i question everything you say any way. :jawdrop:
  • psylo535
Posted September 28, 2012 - 02:59 AM
Oh ! So did you get it together for this weekend ? The guys wre talking about Bartow again. I don't know about that
  • Hot  28 replies
  • Hot  113 replies
  • On January 15, 2017
  • 10 replies
