making a 03 yz450f street legal
9 replies to this topic
  • yz450fbeast
Posted September 14, 2012 - 08:19 PM
just got a 03 yz450f today and wanted to know what was needed to make it street legal
  • corndog
Posted September 15, 2012 - 10:33 AM
WR flywheel & stator
Lighting kit
Left mirror
DOT tires
Speedo
I'm sure it varies a bit by state, but I think that's pretty much it...
  • rknaub
Posted September 15, 2012 - 08:35 PM
A horn is required where I live.
Posted September 16, 2012 - 11:10 AM
You cannot install the WR450 flywheel or stator on an '03-'05 YZ450 without changing the crankcases, crankshaft, and left crankcase cover.
  • corndog
Posted September 16, 2012 - 04:46 PM
Woah, good to know, thanks for the correction! I guess they're only interchangeable between the YZ/WR 400 & 426?
Posted September 17, 2012 - 06:31 AM
Yup. An '06-'09 YZ can be converted without changing the crankcases, but you still have to change at least the left side of the crank.
  • corndog
Posted September 17, 2012 - 10:23 AM
Okay, so does this look right?
1998-2002 YZ/WR 400/426 - Stator/Flywheel are all interchangeable.
2003-2005 YZ 450 - Must change both [color=#282828]crankcases, crankshaft, and left crankcase cover, in order to install WR stator/flywheel.[/color]
[color=#282828][2006-2009 YZ 450 - Must change the left crank half (or entire crank) in order to install the WR stator/flywheel.[/color]
[color=#282828]Do you know if the 2010+ WR stator/flywheel work on the '06-'09?[/color]
[color=#282828]I'm looking at picking up a 2010+ YZ450 in the couple/few months, I don't imagine any WR parts fit that motor?[/color]
Edited by corndog, September 17, 2012 - 10:24 AM.
Posted September 17, 2012 - 11:03 AM
The '06-'09 also requires the left crankcase cover from a '07-'11 WR. The starter motor hole will need to be plugged.
'10+ YZ450's produce 140 watts as it is, and they have a DC system, so they have no need for additional power.
  • corndog
Posted September 17, 2012 - 07:14 PM
Great info, thank you sir!
  • EGPeil
Posted October 03, 2012 - 07:22 AM
Find an e-Line stator for the 03-05 YZ450F and you don't need to change the crank or cases. e-Line doesn't make them any more so you have to watch eBay or post something here looking for one - that's how I found one.
  • Hot  50 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
