'03 WR450 neutral wire?
2 replies to this topic
  • RipGroove99
Posted September 12, 2012 - 05:47 AM
Installing a gear indicator on my Supermoto which requires a neutral signal, so where's the best place to take that from? I hear there's a blue wire going into a connector plug under the tank, is that what i need? If so can i just splice in to it? Are there any other neutral signals anywhere on the bike?
Also i need a positive and negative to power the unit so rather than take straight off the battery so it doesn't drain, where can i take these feeds from so that they only power the unit when the ignition is on?
As you can see I'm not great with electrics so any help appreciated :-)
Edited by RipGroove99, September 12, 2012 - 05:52 AM.
  • nnamssorxela
Posted September 12, 2012 - 06:44 AM
This might help you out a bit. Not sure how the '03 is different.
  • RipGroove99
Posted September 12, 2012 - 07:43 AM
I did see that thread thanks, i guess I'll have to try that blue wire and see what happens. Any idea how to wire up the power source so that its only on when the ignitions on?
