2006 WR450 Dies if I Push the choke in Please help!
4 replies to this topic
  • NoMoreSmoke
Posted September 10, 2012 - 09:06 AM
Here is the deal. I Just bought a WR 450 2006 and its hardly been used. Everything is in great shape but it just won't stay running for me unless the choke is out. When I got it home I drained the gas because it had defiantly gone bad, and I flushed the tank before refilling it.
I have removed the carb cleaned it inspected jets ran copper wire thru jets
I live in MN and I have the following jets in it. Oh and the bike is stock...
Main Jet is 165
JN OBDWR only has one position on it
Pilot Jet 45
Start jet is 65
Air jet is an 80
Fuel air screw is set to 1.5 turns out I have gone past 1.75 turns ( this does stop the back firing)
These all seem to be stock if my research is correct.
What am I missing should I throw some seafoam in it and go for a ride and see if that loosens it all up??
Please any help is appreciated.
Mark[font="Times New Roman"][color=#000000].[/color][/font]
Edited by NoMoreSmoke, September 10, 2012 - 11:20 AM.
  • MANIAC998
Posted September 10, 2012 - 02:30 PM
While your on the right track, I would suggest tearing back into the carb and replacing the pilot jet instead of just cleaning it. They are notoriously hard to get perfectly clean, what with them being so small. Check the "pinned" posts at the top of this forum to see what size jets you should be running for your location. This, along with an in-line fuel filter should fix all of your issues.
Maniac
  • Rocky739
Posted September 10, 2012 - 02:31 PM
This has been discussed a million times but since your new, you have a clogged pilot... You need to replace instead of clean.
  • jetfuel
Posted September 10, 2012 - 03:34 PM
You may also need to clean the fuel circuits/passageways in the carb body itself.
  • Leardriver
Posted September 10, 2012 - 06:18 PM
That bike runs a little better with a 48 pilot at around 2.0 turns out.
You have been given great advice about the clogged pilot. Suspect that on any bike that has been sitting.
