YZ Engine swap in a WR
3 replies to this topic
  • LIV4MUD
Posted September 07, 2012 - 07:17 AM
I have a chance to buy a street titled WR400 in great shape for dirt cheap. Only thing is that the motor is garbage. I can buy a complete YZ450 motor off e bay from a 2005. Can this swap be done easily or will it not work at all?
  • Spiritwalker2222
Posted September 07, 2012 - 09:37 AM
No, it can't be done easily.
  • Ssquared
Posted September 17, 2012 - 05:53 AM
as far as I know the frame geometry is the same. I think the only difference is the swing arm pivot bolt diameter.
  • loco4x4
Posted September 18, 2012 - 07:19 PM
I put my 2002 WR426 motor into a 1999 YZ400 frame that was plated. As I swapped everything from the '02 to a bare '99 frame, I drilled the 17mm swing arm pivot bolt holes in the frame up to 18mm.
Mine was relatively easy as the 400 and 426 cases are the same. I wonder if you can say the same for the 450. Be careful about placement of other engine mounting holes.
Good luck! It's nice having a plated dirt bike!
Edited by loco4x4, September 18, 2012 - 07:22 PM.
