need help with my 2004 yz450f
No replies to this topic
  • aligshow
Posted August 27, 2012 - 02:33 PM
I have a 2004 yz450f and i cann't get it to kick start at all. installed a new je piston about a month ago start four different time in garage and ran great.
1) compression.
je piston 13.5 to 1 only a month old
the valve clearance is good .20 to .25 for intake and .10 for exhaust
timing is prefect the "I" is lined up below and the marks on the cams line up with top of the heads the other marks are around 12 o'clock.
2)Spark
new coil and spark plug. did a spark gap test .misfired around .30
did an ohms test and every thing is with spec
cdi test good and sparks at the right time.
3) Gas
i only vp fuel
carb is clean
have good vac from the engine
any ideas? please help
  • Hot  50 replies
  • 10 replies
  • 0 replies
