Edited by clayba12, 24 August 2012 - 02:34 PM.
wont idle...help..
Started by
clayba12
, Aug 24 2012 02:33 PM
6 replies to this topic
Posted 24 August 2012 - 02:33 PM
i have this 2004 250x that i had running absolulty awesome. then i moved from far east texas to far west texas (3000 ft elevation increase) and the bike sat for about a month. now i CAN NOT get it to idle. before i moved i had the valves adjusted and it was running awesome. Any ideas or recommendations to get it to idle and to set the jetting? also, i can run and jump start it no problem and when im riding, it backfires aweful when im coasting. but when i pull the clutch it will die instantly. ANY ideas? thanks!
Posted 24 August 2012 - 02:39 PM
check your jets in the carb. the one that controls the low rpm might be dirty, not allowing enough gas to flow through, causing it to die. add just a little starter fluid in the carb before you put it back together. and lastly raise the idle just a tad. that would be my only guess. let me know if it works
Posted 25 August 2012 - 07:03 AM
First thing is to drain the old gas and put fresh in and make sure the air filter is clean. Then adjust the Air/fuel screw out
1/4 turn at a time and see if that works. Going up in elevation has leaned you jetting out. If it still wont idle take the jets out and clean them. It could be a clogged pilot jet. You may need to go up in size on the pilot.
Best if you can tell us what your elevation is now and what size jets - pilot and main, what groove the needle clip is in and what mods you've got - air box, pipe, a/p...
Posted 25 August 2012 - 07:14 PM
I would say what the others said, carb neededs be cleaned. But I thought going up in elevation would make your bike run richer not leaner....
Posted 26 August 2012 - 08:11 AM
Clayba12, Go in with the air/fuel.
Sorry if I caused any confusion.
Posted 03 September 2012 - 06:06 AM
ok thanks! im not sure what everything is set on but i'll find out. i know im at 3000ft elevation now instead of 300 where i was at. i'll take the carb off again and see what i can find out
Posted 03 September 2012 - 02:44 PM
I know it does not sound related, but ANY TIME a CRF won't start, check the valve clearance before going any further. If you had to re-shim the valves, you only get a few hours run time before they zero again. It just sucks to chase a problem all over the place, then finally check valves and they are zero'd. Makes you really feel like an idiot (don't ask how I know).
Where are you? I am in Midland and can give you my settings and/or take a look at it for you if you are close to here.
Edited by rmoore0852, 03 September 2012 - 04:39 PM.
