frustrated wr 450 owner help
5 replies to this topic
  • mtahoe
Posted August 21, 2012 - 07:52 PM
Getting sick of working on this bike had it running and now just idles for a bit then starts popping and stalls. What are the simptoms of a dead brain/cdi cause this things is making me crazy. changed stator ran good for a bit now same shit... thanks need help...
  • mtahoe
Posted August 22, 2012 - 06:12 AM
Going back to carb seems it must be something there, could the fuel mixture screw go bad and not seal anymore.....
  • Spiritwalker2222
Posted August 22, 2012 - 06:35 AM
The o-ring can dry out and crack. But with mine a 10 degree temp change and humidity change will warrent a little fiddling with the fuel screw to get it working properly again.
  • GuyGraham
Posted August 22, 2012 - 11:15 AM
fried CDI = no worky
when they go bad, they normally stop working altogether
have you had the carb apart and cleaned it all
clogged pilot jet normally results in idling issues
not worth cleaning, just get a new one
  • DrFeelGood
Posted August 23, 2012 - 11:52 AM
Normally, but not always.
Stick your CDI in the freezer for 3-4 hours. Remove it and immediately plug it in to the bike and see if it runs better. Thermal intermittants (usually bad solder joints ) are not uncommon on CDIs.
  • mtahoe
Posted August 28, 2012 - 06:10 AM
Just so you guys know it was the coil the whole time so glad the bike is back to running normal. It was so intermitent had to diagnosis. love this forum!!!!
