Front brake line - Is this right?
8 replies to this topic
  • bad mechanic
Posted 21 August 2012 - 04:50 AM
I installed my new HEL front brake line over the weekend, and I have it clamped at the very end of the stiff section of brake line, but it sticks out from the fork leg just like my stock brake line used it. Could someone tell me if this is normal or not? I suspect it is, since my stock one did it as well.
  • FloppyJunk
Posted 21 August 2012 - 05:41 AM
I think it'll work but heres how it should be...
  • backyard hack
Posted 21 August 2012 - 06:00 AM
The SM brake line runs on the outside of the fork leg
The S and E has the brake line as above
Edited by chooken, 21 August 2012 - 06:01 AM.
  • restosud
Posted 21 August 2012 - 06:27 AM
yeap.you got it right.
  • Moterreal
Posted 21 August 2012 - 06:30 AM
Do you have a pic of what the top of your front brake lines look like?
  • taiguy
Posted 21 August 2012 - 07:06 AM
That's what mine looks like after putting on SS lines.
  • ptgarcia
Posted 21 August 2012 - 08:37 AM
I would pull it in more with a zip-tie or clamp.
  • Joester
Posted 21 August 2012 - 10:11 AM
That's how its supposed to be. There wont be a problem unless you plan on riding through heavily wooded areas on a regular basis. :smirk:
  • subeng
Posted 21 August 2012 - 10:30 AM
S & E brake line has to be routed around the outside of the fork leg as well if running SM wheels.  I just put Warp 9 SM wheels on my S and had to route the line around the outside of the fork, inside the fork would not work due to the 320 front rotor, it would have chewed it up in a matter of miles.  The stock S length brake line is not long enough to route it the way you would need to inside of the fork with a 320 front rotor.
