need help with a 2007 crf250x
Posted 20 August 2012 - 03:18 PM
Also wont fire up with E start relay just rattles so im guessing bad relay or bad battery?
Posted 21 August 2012 - 04:31 AM
My guess is that you probably have intake valve wear and that's why it is not staying running. Check your valve clearances. There is a sticky here that shows you how to do it. My guess is intake valve on right hand side has worn and there is no gap between cam and bucket.
Posted 21 August 2012 - 07:11 AM
As for the Air/fuel screw, the stock screw is a pain to use. Best bet is to buy a "BRASS" aftermarket T-handle screw for around $15 or a flex screw for around $30. DO NOT BUY AN ALUMINUM SCREW.
Posted 21 August 2012 - 07:12 AM
And for the screw i have a flex screw im guessing its mounted on clutchcase side and wraps to to kickstart side.Its weird cause when he brought the bike over that screw was so far out,i dunno on theese but ive always known an idle screw to be 2-3 turns out from closed correct?Also if this helps it bogs when i hit the throttle idling in choke,too me it feels like its not getting gas so maybe ill check the jets like mentioned?
Edited by SNYPER, 21 August 2012 - 07:16 AM.
Posted 21 August 2012 - 09:58 AM
I know its a lot of things to check but the more you can tell us the better.
As for the battery, it sounds like its toast. Try and charge it. If you need a new one, go with the 450x battery or equivalent. It will have more cranking amps and will start much better.
Posted 21 August 2012 - 05:49 PM
As for mods ive seen a few in theese forums but i dont think this bike has any,.would cutting the top of the filter box open like ive seen benefit me or the pink wire trick?
Posted 22 August 2012 - 07:33 AM
Dont mess with the pink wire. That mod only comes into play if/when you swap ot the cam to a Hot Cam or R cam.
The Air/fuel screw on that year is a pain to use on the trail due to the notch you described. Go with one of the aftermarket ones i spoke about. They make it simple to adjust on the fly.
The needle that year sucks because its not adjustable. Go with a 06 or earlier needle or get the JD kit.
The JD kit is your best bet as it comes with pilots, mains, needles and O-rings for the A/P mod. For $70 you will have everything you need to get the jetting where you need it.
Glad you got it running.
Posted 22 August 2012 - 11:02 AM
Posted 22 August 2012 - 12:51 PM
Posted 06 September 2012 - 03:23 PM
Posted 06 September 2012 - 04:50 PM
I used to have the T-handle fuel screw adjuster and it is still a pain in the a$$ to adjust because the starter motor is so close to it. In my opinion the only way to go is with the R&D Flex Jet fuel screw.
Posted 08 September 2012 - 09:35 AM
Cant wait to do some upgrades,Any recomendations for easiest most gain upgrades? Def gonna jet it.
