helo, i am converting my 250r 3 wheeler into a 500. i want to use the LT500R motor in stead of CR because i was told its literaly bolt on. ( new motor mounts need to be fabbed) what im asking here is what are these engines compared to a cr 500 motor? are they basicly the same power? please help, thanks. can some one tell me the hieght on the lt motor? thanks. from bottom to spark plug. thanks
atc 250r to 500r
Started by
william16339
, Aug 20 2012 11:54 AM
4 replies to this topic
Posted 07 October 2012 - 01:55 PM
the lt500 doesnt hold a candle to the cr500 or kx500, the lt500 will keep up with a 250 stroke dirtbike, wont even come close to a cr/kx, id put the cr500 motor in.
Posted 07 October 2012 - 10:09 PM
I had both a 1985 atc250r and a 1987 trx250r that i swapped to a cr500 motor.the cr500 motor destroyed the trx frame.the atc motor has a balence shaft.the cr500 motor doesnt.If you look close at a cr500 dirt bike frame bare you will find that its not very long and most of the vibration stress is in a vertical plane so the bike frame can take the stress better.The atc frame is close to the bike frame -not long like a trx frame.In the end I rode the old atc more than the trx becuase the trx allways had some kind of problem.I took both to pismo for a 3 day weekend once and the trx500 ran all 3 days.when I got home I started my usual maintenance and ended up tearing the trx500 completely to a bare frame and welding up 12 stress cracks.I had my buddy that helped build the 500 ride it and I rode my atc out to that big semi-flat area at the south east corner of pismo and we drag raced to 80-90 mph 3 times.the trx500 would get the atc out of the hole but at 60+ mph the atc would reel the trx500 in-less drag and a 6 speed vs 5 speed trans on the 500.The atc carried me back from boardmanville to the canal area at glamis many times at 1 or 2 in the morning without a problem.The atc had a +3" swingarm.engine was ported with an aftermarkit pipe and silencer.carb was stock-rejetted with no air box lid.The poor old atc also got to run around San Felipe on the highway and with the 6 speed running 20" holeshots you could run 55-60 mph on the highway if needed.If I was going to play with a cr500 I would just buy an old beater and put a paddle on it.A good running atc250 r is just as fast as %90 of everything else with out much headaches.
Posted 06 January 2013 - 06:09 PM
I have a kxt500 it's fast can take most banshees has a bad rear shock so always have to slow for any bumps
Posted 16 May 2013 - 07:49 AM
The cr500 motor is way more dependable and has more power to boot. A lot of work needs to be done to the frame tho to make is a solid rider without crazy vibration.
Follow us:
