2006 cr 250 questions?
4 replies to this topic
  • TrickyCR
Posted 18 August 2012 - 10:10 AM
Hey
iv owned the bike now for 2 months and its being in my garage for over a month now, just sat looking sorry for itself as on only the second time out on it, the throttle stuck on and sent me flying over a burm and into a wood ( whitch hurt alot resuting in many hospital trips and a month of work so far )
now my friend rode the bike back to the paddock once id been taken to hospital and it was fine. when i got it back to mine my mate started it and it seemed fine. iv striped the whole carb and throttle mechnism down and nothing seems wrong??? i cant remeber if i left the fuel tap on for the first week as then the tank was taken off, then it was left for another 3 weeks and today the reeds were taken off so i could then see into the crank area and its full of fuel like the crank is submerged in fuel???
im confused as to why its full of fuel? is the only way its full because i left the fuel tap on?
Next question is im going to be very nervous getting back on the bike without find anything wrong, can the only way a bike fly off like the throttle is wide open be if the slide in the carb is open??  is it possible for it to fly off even if this is shut?? like what else can cause a bike to fly off??
any idea would be great thanks
  • JJRace
Posted 18 August 2012 - 12:52 PM
either you didnt turn off the fuel or the petcock is leaking when turned off.
remove the tank and spark plug, turn the bike over and kick it over by hand to try to get some of the fuel out.
If you have an air leak, a 2 stroke will be like WOT.  That is more than likely the issue.  Check the head, base, reed gaskets.  Then inspect the left side crank seal or just change it out.
  • Kmiller2723
Posted 18 August 2012 - 04:05 PM
The only things i could think that would fill the crank case with gas is if you gas was on and somthing was wrong with you floats or needle. Either the floats got stuck open, there is a crack in your floats, or your needle is bad. As far as the bike sticking wide open i agree with a possible gasket leak or if the throttle cable has a kink in it or is routed improperly, that can cause the bike to get stuck wide open.
  • RGVMelb
Posted 19 August 2012 - 11:18 PM
If you're suspect on the gaskets being stuffed or an air leak anywhere on the engine spray something flammable around your motor etc, (while it's idling) and if the revs change there is a pretty good change air is getting in somewhere.
Any chance you could have got some dirt/grit stuck in your throttle tube?
Good luck mate and a speedy recovery to you. I know what it's like being injured and there isn't much worse than not being able to work or enjoy the things you want too.
  • TrickyCR
Posted 20 August 2012 - 09:55 AM
hey thanks for your replys!
Is an air leak more likely to be from the carb side and not the head or barrel base? i would have thought coolant would also be leaking in if air would?
Regarding the carb i thought its got to have something to do with the float as im sure alot of people leave their fuel taps on and if every bike in the world filled the crankcase with fuel then there will be alot of bikes not starting and there has to be a carb issue. could a float issue or needle issue cause the bike to go off on like its on wide open throttle!
im just trying to gather as much info for when i go back to the bike. If there isn't a air leak is the only way it can go off like that be that the slide ( not sure if thats the correct term for it ) is open?
throttle tube did have a slight bit of dirt in it so could have been that but not sure.
i wish there was a way of having a push pull throttle fitted like 4 strokes do!
Im mechanically minded so have no problem in doing the work myself but im a car mechanic and unless i have tech info for setting the carb up then im screwed! i think i may just give the carb to someone who knows their stuff about them or is it quite easy?
Also it sucks being off work as i cant afford to fix the bike at the moment as my sick pay from work is getting stretched as far as possible so as soon as im back at work i can then get the bike fully sorted and hopefully get back out on her :thumbsup:
Edited by TrickyCR, 20 August 2012 - 09:57 AM.
