Andrea Bartolini YZM400F engine and project.
80 replies to this topic
  • artracing
Posted November 22, 2013 - 04:14 AM
#41
WOW, I've officially drooled here...thanks for those pics. :thumbsup:
It's amazing to see Yamaha put that level of effort and expense in to an effectively low number of prototype engines.
Begs the question who still has the drawings or CAD files to knock out a few more on a milling machine!!
As grayracer mentions, in the past there were some weird builds by the manufacturers. Honda made a 5 cylinder 125 four stroke. The pistons must have looked like thimbles! And it's hard to comprehend how the weight of all those reciprocating parts and the valve gear would be an advantage when one considers the frictional losses. And there was the oval piston NR500, basically a V8 but with only 4 cylinders to get round rules.
This YZM single cylinder engine is far more conventional in design but just as intriguing when you consider how they optimised it for it's intended purpose.
It's great to see this sort of project and I'm certainly looking forward to seeing it come together even more so now. Cheers.
Considering this IS the prototype engine that started the four stroke revolution. The return on investment is in the billions I would think now. They still can implement some things in this design into new YZ450 bikes, if they feel it worth while. Twin port exhaust, shorter rod stroke, higher compression etc.
This engine has 62ish HP and higher rev limit then stock.
I hope to have bike running in the next week or so. My only issue is the zeeltronic CDI. I need a startup timing map. I am using TPS and have 12 RPM points I can use.
Posted November 22, 2013 - 07:41 AM
#42
The Honda 5 cylinder 125 made horsepower in unbelievable gobs because of the rev range it operated in; it was redlined at 24,500 rpm, and long before F1 cars reached the 20K barrier.  Then there was the 6 cylinder 250 they expanded to a 297 so they could use it to dominate the 500cc class.
Moto Guzzi, of course, actually built a 500cc V8 before 1960.
  • artracing
Posted November 22, 2013 - 09:40 AM
#43
Where is that 5 cylinder? Amazing!
  • artracing
Posted November 22, 2013 - 09:43 AM
#44
Little dress rehearsal. Still have good 40 hours of work to do before firing.
Posted November 22, 2013 - 10:30 AM
#45
http://www.motorcycl...ivecylinder.htm
http://www.deejay51....HALL RC149C.JPG
http://www.google.co...385231292876823
http://1oldtimer.fil...inder.jpg?w=900
  • 72degrees
Posted November 22, 2013 - 10:34 AM
#46
Listen in awe (also features early four cylinder machines): http://gilera.org.uk/Audio/TT.WAV
Edited by 72degrees, November 22, 2013 - 10:36 AM.
Posted November 22, 2013 - 10:42 AM
#47
Link doesn't work unless you're registered at the site.  Try this:  (watch the tach. the bike won't stay running below 10K)
Posted November 22, 2013 - 10:43 AM
#48
That's going to be such a piece of work when it's finished.  Absolutely beautiful.
  • 72degrees
Posted November 22, 2013 - 11:02 AM
#49
Beautiful music!
Ah, I put the link in first without the file name. It's my site in a public folder so it should work now I hope.
  • artracing
Posted November 25, 2013 - 04:08 AM
#50
Begs the question who still has the drawings or CAD files to knock out a few more on a milling.
Well, I have the engine, can get a 3d scanner, and can get the solid modeling done and do the machining.
Only one problem! $$$$ . Want to be an invester?
Who is the racing market that's not controlled by some sanctioning body?
  • rmxdan
Posted November 25, 2013 - 12:25 PM
#51
Hmm :thinking: ............. Much as billet components appeal to me, I'm more of a 2 stroke sorta guy, and all that farce stroke engine's extra components would cost more than I could justify investing in. :smirk:
It is true that more people have access to CNC machines these days which does offer so many possibilities.
In the past I've had several batches of different components made up in large enough numbers to make it worthwhile putting in the effort to get them designed and drawn up into a file.
  • cowboyona426
Posted November 25, 2013 - 04:36 PM
#52
That thing is unreal sounding!
Agreed 100%, looks amazing so far!
  • aremean_troy
Posted November 26, 2013 - 08:57 AM
#53
wow!!! Simply amazing!
  • artracing
Posted December 06, 2013 - 04:59 AM
#54
As Frankenstein said, She's alive!!!!! After 15 years of silence
http://huskyrestorat...CAB8130DE7C.MOV
Want to thank Krannie for helping with timing curve and carb.
Hope to have it revving today.
  • artracing
Posted December 07, 2013 - 10:45 AM
#55
Except for some tuning, SHE IS DONE.
Your going to like this.
First time in 15 years anyone as heard a YZM400
http://www.advancedr...com/YZM2013.mp4
Thanks to Doug Dubach for remembering the carb set when he ran this engine in the day.
I'll do better video in future.
Edited by artracing, December 07, 2013 - 10:47 AM.
  • cowboyona426
Posted December 07, 2013 - 10:19 PM
#56
Very nice!!!
  • HRC
Posted December 13, 2013 - 02:14 AM
#57
The real deal...
  • HRC
Posted December 13, 2013 - 02:38 AM
#58
One more vid on the real deal...
  • artracing
Posted December 15, 2013 - 05:44 AM
#59
LOL I guess I have half the real deal, but I do have the only electric start version. I took the same video at Hall of Fame, the year before last, to use as my reference.
Hmmm , my bike is half works and half recreation. What we call it?
  • rmxdan
Posted December 15, 2013 - 06:52 AM
#60
50/50 works re-creation?
I noticed this thread the other day.
http://www.thumperta...ay-thumpertalk/
It seems these YZM400F bikes may be the very reason ThumperTalk came to be.
