2006 150 stock chain length
7 replies to this topic
  • BigXR400
Posted 17 August 2012 - 11:04 AM
Guys
    I've done a search for this and came up blank or with different answers. I have a 2006 cfr 150 electic start and need to know what chain length to get. I see that the 2006 crf 150 is the cut off. I see that some are 104 links and some are 112 links. I just need to know witch one to order. The bike has stock gearing. If I get a longer chain that is fine, I have a chain tool to take links out. Would some one let me know. Thanks!!!!
  • Confederate
Posted 17 August 2012 - 01:58 PM
According to the Honda web page stock is 104L long. If you have the old chain just for  kicks count the number of links to be sure.
  • BigXR400
Posted 17 August 2012 - 02:06 PM
Thanks for your help. I counted the number of links and I cam up with 52 so I doubled it and came up with 104. Thanks that was easy!!!!!
  • Confederate
Posted 17 August 2012 - 02:19 PM
The number of links refers to each pin. You count all the pins in the chain and add 2 for the pins in the master link. If it was the stock chain from the factory it did not have a master link in it and have to use a chain breaker to remove. New chain comes with master link usually.
  • BigXR400
Posted 17 August 2012 - 02:44 PM
This is a stock o ring chain it has no master link. O rings are starting to work their way out. Need new one. Rock mountain sell them at pretty good price. Going to order one to day.
http://www.rockymoun...H-X-Ring-Chain.
  • BigXR400
Posted 17 August 2012 - 02:46 PM
Do you happen to know the Tork setting on the rear acel nut on the 2006 crf 150. Thanks
  • Confederate
Posted 17 August 2012 - 03:19 PM
Not sure but would think it would be the same as the 230 which is 80 ft. lb.
  • BigXR400
Posted 17 August 2012 - 04:08 PM
I did it at 75, 5 more it is! Thanks
