DRZ 125 Float Needle Valve Assembly Removal Help
Posted 15 August 2012 - 09:58 AM
I have a 2004 Suzuki DR-Z 125 I bought from a guy who let it sit for the last 3 years. I took apart the carb last night and it was all gummed up inside. So I carefully cleaned it all out, jets and all passages. But, when I put it back on the bike, the float bowl will not fill up with gas when I turn the petcock on. I took it apart again and took off the float bowls and it seems like the Float Needle Valve Assembly is frozen and simply not letting any gas into the bowl no matter what.
I want to replace it, so I have ordered a carb kit from the dealer. My problem is I don't know how the needle valve assembly comes out and I don't want to break anything. Does it simply pull out with fingertip pressure? Or, does it screw out? I assume from looking at the schematic of the carb that there is also an o-ring inside as well.
Any help would be appreciated. I'm kind of waiting to hear from some people before I try and pull that thing out.
Thanks!
Posted 15 August 2012 - 12:41 PM
Posted 15 August 2012 - 02:30 PM
TWOWHEELTOM, on 15 August 2012 - 12:41 PM, said:
Thanks, I'm going to give it a try tonight.
Posted 15 August 2012 - 03:00 PM
Little more help as I just ran out into the garage to give it a try. Does the tiny little pin that goes up and down actually pull out of the larger brass looking cylinder? Or does the whole thing come out. Also, is that larger brass cylinder (that it is sitting in) simply pulled out or is it screwed in?
Posted 15 August 2012 - 03:50 PM
Posted 16 August 2012 - 09:48 PM
TWOWHEELTOM, on 15 August 2012 - 03:50 PM, said:
Posted 17 August 2012 - 08:04 AM
Posted 18 August 2012 - 08:59 PM
History: bought a 2004 DRZ 125 that had been sitting for 3 years and would not start. I pulled off the carb and cleaned the following...
In the Float Bowl...
- Replaced the Needle Valve because it was stuck closed and starving the bowl of fuel. (this basically fixed the no start problem)
- Cleaned the Main Jet
- Cleaned the Pilot Jet
- Cleaned the "Main Air Jet"
- Cleaned teh "Pilot Air Jet"
- Cleaning the "Needle Jet" (I think that is what it is called...the one that looks like a long needle and has a big spring around it and is attached to the throttle cable when first taking the carb off the bike).
- My Fuel/Pilot screw still has the brass plug, so I did not touch it. If I drill it out and remove the screw, o-ring and spring is it possible there is varnish or gum from the old bad gas causing all my problems. Or, is this just a screw to adjust how rich the gas mixture is and bad gummed up gas can not affect this screw?
Posted 19 August 2012 - 05:02 AM
There is a diaphragm mounted on the side of the carb under a cover, take that apart and double check that it's ok and be sure not to damage it with the compressed air or cleaning fluids. you can read in the vintage forum about folks soaking carbs in Pinesol to clean them. It works ok . I'm more a fan of an ultra sonic cleaner but you probably don't have access to one.
Posted 20 August 2012 - 01:28 PM
Posted 20 August 2012 - 01:49 PM
JeffGolem, on 20 August 2012 - 01:28 PM, said:
Posted 20 August 2012 - 03:29 PM
JeffGolem, on 20 August 2012 - 01:49 PM, said:
Posted 02 September 2012 - 11:30 PM
I finally got the right Pilot Jet in the mail today.
In case this helps anybody else in the future. I have a 2004 DR-Z 125 that was hard to start. I drilled out the fuel screw. 1/8" drill bit, put a piece of tape 1/8" onto the drill bit so as not to go too far in. Then I tapped in a machine screw about 1/8" and pulled out...the plug came out really easy. I turned in the screw until it stopped and I counted that the factory setting was at 1-1/2 turns out. I then srewed it out, taking care to account for the spring and metal washer. Then, I cleaned out the opening with carb cleaner and put back the screw and turned it all the way in, then backed it out 2-1/2 turns out. Then I installed my new pilot jet. The stock OEM carb on the bike is a Mikuni VM20SS with the stock pilot jet being 17.5. I went up one size to a 20. This, combined with backing out the fuel screw as advised by others to 2-1/2 out.......the bike started on the second kick!!! I used to have to kick it about a hundred times, then give up and spray starting fluid and hold the throttle about half way until the bike warmed up. Not anymore! Now the bike is ready for the wife to ride!
Thank you all again for all your advice and help. Just wanted to post this follow up as a thank you.
Jeff
Posted 02 September 2012 - 11:32 PM
Jeff
